20 Most Recent Epson LQ-1050 Matrix Printer Questions & Answers
If you have the CD which you might have received with the printer go ahead an install the driver software using the CD.
If you don't have the driver CD to install the Printer Driver go to this website to download the driver for the same.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Downloads&oid=14323&category=Products
If you are install the printer using the CD, try not to plug in the usb cable in the begning/ the driver software will ask you to connect the usb cable so try to connect it at that time.
Epson LQ-1050... | Answered on Feb 11, 2013
Replace head or take to service for replacing some needle at head.
Epson LQ-1050... | Answered on Jun 30, 2010
The "data" cable for a printer either is:
* USB -- a small almost-square socket, less than 1/2 inch (1 centimeter),
* parallel-port -- a very-wide connector, more than 2 inches (5 centimeters).
Some printers have *BOTH* connectors.
Determine which connector(s) you have, and buy a cable.
Often, a "Thrift Store" will have the "parallel-port" cable for a dollar.
Don't pay more than $4 for a "USB" cable.
If you're buying a USB cable, make sure that there is a "square" end -- some USB cables have a smaller "mini-USB" connector, in order to connect to a digital camera.
Epson LQ-1050... | Answered on Nov 27, 2009
When the drivers are not available, you can install VMware virtual machine and be able to use windows xp and xp drivers to run your print jobs. The basic VMware is a free download and works well on my Vista machine.
Epson LQ-1050... | Answered on Nov 25, 2009
I am getting my text cut off at the bottom what could be the problem
Epson LQ-1050... | Answered on Nov 04, 2009
Not all dot matrix printers will print in draft mode. When operating from DOS it was usually necessary to send an Esc(ape) code such as ESC @ in ASCII code. I don't think it can be done from Windows; in fact some windows programs will not even talk to a dot matrix printer. Some printers have one or two banks of DIP switches, but before changing them you need to read the manual to see what they do. There could be one which allows Draft MOde.
Epson LQ-1050... | Answered on Sep 24, 2009
what type of operating system are you using?, if so pls try to update your driver. or install and reinstall that particular driver.
pls try to visit www.epson.com where you can find their latest updates on drivers
Epson LQ-1050... | Answered on Sep 10, 2009
45 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
LQ Epson
  • LQ Epson
Most Popular Question
sir want download wipro lq 1050 printer
  • Office Equipment & Supplies
