20 Most Recent
Epson Stylus C62 InkJet Printer Questions & Answers
Epson stylus c62 went bang!
Well wish I had good news. Sounds like you're voltage distribution board got fried. BUT before we pronounce it dead, are you getting any codes at all? Or is everything blank? If your getting nothing, nothing you can do. Did you plug into wall or power strip? For grins, try one more outlet.
No printing black ink
You may have blocked print head nozzles.Try the printer maintenance to clear the printer nozzles.After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Printer won't print black
In view of the original poster's lack of interest, I think we can call this one "Solved by Poster".
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this solution if it has helped you
How can I download installation
You can download the drivers for Epson C62from Epson Official Support. Click
here to visit the site and download the drivers for the Operating System you have on your Computer (e.g. Windows XP) .
Hope it helps! Good Luck!
CreativeTECH
