20 Most Recent Epson GT 7000 Flatbed Scanner Questions & Answers
3answers
How can I get my epson GT 700 scanner to work on windows XP
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
5/3/2013 10:40:10 AM • Epson GT 7000... • Answered on May 03, 2013
I need driver(s) for a
You can get support here on this free site : EPSON SCANNER
Be particular with the model you wish to download...
Good luck...
6/23/2011 10:13:19 AM • Epson GT 7000... • Answered on Jun 23, 2011
BEST SCANNER FOR A NEWSPAPER
Wow. Next time I want to scan a newspaper, I'll remember that. Thanks.
4/5/2011 9:14:32 AM • Epson GT 7000... • Answered on Apr 05, 2011
5answers
Can someone advise if the Epson GT-7000 scanner
I got mine working on Windows 7 (x64) by doing the following:
1. Download the Windows 7 Epson Scan driver for the Perfection 2400 from the epson site 2. Install the drivers 3. In Start Menu->All Programs->Accessories right-click Notepad and select Run as administrator 4. In Notepad File->Open and browse for the es27.inf file located in C:\Program Files (x86)\epson\escndv\es0027 5. On line 51, 54, and 57 replace PID_011B with PID_0101 6. Save the file. 7. Connect and turn on the scanner. 8. In Device Manager (Start Menu, right-click Computer, select Properties, Device Manager) right-click the scanner and select Update Driver Software->Browse my computer for driver software 9. Select the location of the modified INF file (C:\Program Files (x86)\epson\escndv\es0027 Include subfolders checked). 10. Say ok to the window that pops up and it should start installing the drivers.
In Photoshop you should then be able to import using WIA-Epson Perfection 2400 (importing with Epson Perfection 2400 causes Photoshop to freeze)
I hope that works for you :)
Stephen
2/13/2011 2:54:39 PM • Epson GT 7000... • Answered on Feb 13, 2011
Hello, my name is Dino
You should have the driver for this in Windows 7 by default if it works don't worry about it - if it doesn't work - look for it in driver and hardware - remove it and then reboot the pc. The pc will automatically find the printer sand seek out the Driver and install it.
Get back to me for more information and will follow up with you for the next few days if need be.
Gary @ Fix Ya
11/30/2010 4:36:19 PM • Epson GT 7000... • Answered on Nov 30, 2010
0answers
How do i install epson
Download the driver from onto a usb stick if needed. The appropriate driver as per your OS is available at
http://driverscollection.com/?H=GT-7000&By=Epson
11/16/2010 12:05:51 PM • Epson GT 7000... • Answered on Nov 16, 2010
0answers
Looking for a driver for epson gt 7000 scanner for
I do not see this scanner on the Epson support site. They may not have a Win7 driver. You could try an XP driver in the compatability mode (right click on the driver and select Properties and the Compatability tab. Check the box next to Run in compatability mode) You can download a driver from a site like this one, http://download.cnet.com/EPSON-GT-7000/3000-2118_4-73143.html .
Another possibility is available in Win7 Pro and Ultimate. Download and install the XP mode from Microsoft. Install the scanner in the virtual XP computer. You may need to save files to external media to transfer them between the two computers.
I hope this helps.
8/30/2010 12:46:39 AM • Epson GT 7000... • Answered on Aug 30, 2010
I need a driver for my Epson GT-7000 scanner and
Download the epson twain driver from their website: http://www.epson.co.uk/Scanners/Epson-GT-7000/Drivers-Support
When installing, select the driver inside the 2000 folder. It works in XP. You may have to install via the device manager.
Stephen
1/22/2010 1:21:59 AM • Epson GT 7000... • Answered on Jan 22, 2010
Lost software for epson gt 7000 and can't link
Hi Arthur,
Try downloading the drivers from the epson website: http://www.epson.co.uk/Scanners/Epson-GT-7000/Drivers-Support
Best of luck, Stephen
1/22/2010 1:10:12 AM • Epson GT 7000... • Answered on Jan 22, 2010
2answers
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers: *Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing. *Ensure that paper is loaded properly to avoid feeding problems. *Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow. *If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
4/2/2024 6:40:17 PM • Epson Office... • Answered on Apr 02, 2024
Old but New in box epson pictureMate photo lab has paper jam error but never had paper in it .what can i do ?
If you take is apart you may find jammed gears or dry lubricant causing a 'paper jam', due to its age and storage.
2/29/2024 9:14:17 AM • Epson Office... • Answered on Feb 29, 2024
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
2/25/2024 3:05:22 AM • Epson Office... • Answered on Feb 25, 2024
6answers
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer. Step 1: Turn the printer off. Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen. Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons. Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button. Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer. hold the reset button which is on the back of the printer using a paper clip or tip of a pen. WHERE IS RESET BUTON? I CANT FIND IT.
1/30/2024 1:36:34 PM • Epson Office... • Answered on Jan 30, 2024
Head teperaturer error 43H code
I have the code on I dtf printer 43 H : Head Teperaturer
1/19/2024 4:27:06 PM • Epson Office... • Answered on Jan 19, 2024
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head. Here are some steps you can try to troubleshoot and fix the issue:
  1. Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
  2. Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
  3. Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
  4. If the error persists after trying the above steps, you may need to replace the print head.
  5. If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
1/17/2024 4:18:52 AM • Epson Office... • Answered on Jan 17, 2024
Epson GT 7000 Flatbed Scanner Logo
18 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
GT Epson
  • GT Epson
Most Popular Question
need driver epson gt 7000 scanner
  • Office Equipment & Supplies
