20 Most Recent Foxconn 865A01-PE-6EKRS Motherboard Questions & Answers
I have a PC with a Foxconn 865A01 mother board.
Take out RAM and re-insert one stick. Try to power on after this. If you have some thermal paste, also remove, clean and refit the CPU.
10/6/2017 12:09:02 AM • Foxconn... • Answered on Oct 06, 2017
Gateway C51GU01 MOTHERBOARD (no video)
I supose you should test the capasitors one by one.
Faulty capacitors :
http://www.asti-usa.com/support/appnotes/65/2.jpg
if the capacitors arent flat they are possibly bad note in the picture the blue / black capacitors are flat. the black orange capacitors all seem bad. the two are bad for sure.
4/9/2012 12:22:09 AM • Foxconn... • Answered on Apr 09, 2012
I need graphics driver for
follow this link http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=865A01-G-6ELS&TypeID=en-us0000004
and download your desired driver for foxconn 865a01
11/16/2010 7:48:15 AM • Foxconn... • Answered on Nov 16, 2010
0answers
Computer doesnt start FOXCONN 865A01-PE-6EKRS
Most of the times beeping at the start up refers at problems with the memory. So try starting your computer with 1 memory stick at a time, placed at the slot near the CPU (usually marked as DIMM 1) to find out memory error.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
2/27/2010 1:47:33 PM • Foxconn... • Answered on Feb 27, 2010
Compaq Presario Desktop SR1710NX
It;s probably just your onboard video that has gone bad. You can put a video card in the system, then make sure you disable the onboard video in your system bios at startup.
I hope this helps,
Thanks for using FixYa,
Eric
1/26/2009 5:56:35 AM • Foxconn... • Answered on Jan 26, 2009
2answers
How to connect a power in motherboard?
Hi zarathoustra, still have your manual? Go to page 25.
As shown here.
26b4ba3.jpg Little fuzzy.
Need your manual, click this link.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000010
Suggest you save the link.
Good Day!
Mike
4/3/2008 1:01:18 AM • Foxconn... • Answered on Apr 03, 2008
3answers
Motherboard won't start properly
Check PowerSupplyUnit and carefully examine motherboard for bad capasitors: badcaps.com
2/29/2008 2:23:27 PM • Foxconn... • Answered on Feb 29, 2008
2answers
Server continously beeps 5/6 times over and over again
Hi, this type of error alert is most often related to RAM chip failure.
If you have more than one chip, swap them around or try to boot using 1st one chip then the other to identify the faulty one.
Replace this and all will be ok.
Regards mistyman
2/25/2008 6:54:04 PM • Foxconn... • Answered on Feb 25, 2008
2answers
No power
What is making the clicking noise? Is it the case speaker or the hard drive?
Do you use a surge protector?
2/25/2008 6:45:51 PM • Foxconn... • Answered on Feb 25, 2008
2answers
Pc won't power up
Dear Buddy117,
What i have understand that u r Motherboard getting the power supply but i want to know that is u r SMPS power supply fan rotating or not if no then u have to change the SMPS if it is ratating then u have check the power switch in u CPU cabinate is that power switch wire properly connected to the motherboard if it is connected then check wether it is connected in right place or not i hope this information will going to help you.
Regards,
Bittu_8
2/14/2008 7:17:22 PM • Foxconn... • Answered on Feb 14, 2008
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM • Foxconn... • Answered on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM • Foxconn... • Answered on May 13, 2022
Foxconn 6100K8MA/6100M2MA/6150K8MA/6150K8MD Series
ask a question? who,what ,where,why, how,, etc
5/13/2022 11:52:56 AM • Foxconn... • Answered on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like others were sold as DIY from foxconn direct sales. did you lose the PC case? or buy just a mobo , raw? front panel pinouts you meant but failed to say just what:? foxconn (channel) went dead. 2012 the maunuls where there, then, and now all gone. they are gone. all is gone but the echo, (waybackmachine) old Intel P55 / H57 chipset age ,2009, and lost manuals, are are not, lost 2012 year when the went dead. no can find, me....
5/13/2022 11:50:16 AM • Foxconn... • Answered on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM • Foxconn... • Answered on Jan 11, 2022
Manual
is that not out of and HP.com PC? Joshua-H61-uATX (Foxconn 2ADA) sp#670960 hp says used in over 200 produces by them https://partsurfer.hp.com/Search.aspx?searchText=670960-001 step one find PC full model number not told then at HP>com click support the manual is there. see all hp service tag types here for 2 decades https://www.pcdied.com/TAG-jive/tag.html the top of your mobo has this tag https://www.pcdied.com/MoBo/hpz210.JPG and if there the SP# tells what it is. foxconn make mobo for many oEM PCs. this is a fact and the top sticker labels matter only. see more here, for foxconn (now to tell what you have) https://www.pcdied.com/foxconn.html
1/10/2022 12:34:44 PM • Foxconn... • Answered on Jan 10, 2022
Bios detection
DON'T OR SAY WHY YOU MUST? 99.9^% DON'T OR BRICK LIKE MILLIONS HAVE NOW. today is foxconn day;. and they went EOL , DYI in 2019 no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM • Foxconn... • Answered on Jan 09, 2022
Foxconn ml 94v-0 e253117 manual
94v-0 is PCB flame proof spec, certs.e253117, is outside USA, electrical safety certs, both uselessthen land on just ML.,useless too.the mobo I bet has a tag like these, learn to post real sticker tag labels only, not certs painted on the mobo we can not see.andWhat is N15235? (is and electric safety spec #)Often the marking N15235 is mistakenly deemed to be the model number of a mainboard or graphics card, but it's just Foxconn's ACA supplier code number which signifies that the product may be legally sold in Australia.
1/9/2022 11:40:57 PM • Foxconn... • Answered on Jan 09, 2022
Foxconn 865A01-PE-6EKRS Motherboard Logo
16 questions posted
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Foxconn Computers & Internet
Most Popular Question
computer doesnt start foxconn 865a01 pe
  • Computers & Internet
