20 Most Recent
LG 47LM6700 Questions & Answers
Is their anyway you could fix a 47LGLM6700
Unfortunately no, you would need to replace the internal panel on the TV and honestly the labor and part would cost more then just buying a new set in most cases. If the screen has a glass cover and just the glass is cracked but the rest of the picture looks fine (no distortion in the LCD) then you could just remove the glass and run the screen unprotected or copy the dimensions of the glass/plastic and send it away to have a new sheet made to fit.
4/7/2013 8:38:42 AM •
LG 47LM6700
Answered
on Apr 07, 2013
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
