20 Most Recent
Fujitsu AMILO M-6500 Notebook Questions & Answers
I need to access the
Have you tried pressing DELETE? Press the delete button and it will direct you to BIOS. You can then change the boot sequence of your computer so that you can boot to the cd.
Thank you for using fixya,
CARLO
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Is it possible to go in internet?
I have never heard of buying an internet key. You have more than enough memory to surf the web. From how you made it sound, you got taken advantage of.
Toshiba Satellite A50 (A55) Dim screen
what you are describing sounds lile the inverter coil, but you sat you have changed the whole inverter!!
plug the laptop up to an external monitor and please post back
regards
Can i put a more recent Mobo as mine seems to be
Laptop hardware is very proprietary and specific to each system.
To replace the motherboard, you would need the same model as the one you currently have in order to fit the laptop and have your OS recognize your motherboard.
Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
Power problems
If you have a spare ac adapter, try that just to check if it's the ac adapter.
When you power it on, are there any lights on the notebook?
If there are lights, it is indicating that the computer is receiving power but is not able to go through POST ( power on self test ) and normally it's the mainboard that has the problem.
Either way, if there's no lights, it is also the mainboard that is the main cause.
The notebook will have to be sent in for repairs or just replace the motherboard.
Fujitsu amilo laptop
Try making sure your 'num lock' is off and if that doesn't work, try holding fn while pressing the key.
My computer will not restart
It sounds like a hard drive crash but hopefully just one of the core
files. If you get to another computer with a CD burner, download
a copy of the "Ultimate Boot Disk" (find on Google - it's free) and
start the laptop with that disk - you can then use the drive utilities
to test the hard drive.
Fixing graphic drivers for an amilo m 1405 laptop
Reformatting is good only if your system commited a severe damage on it, however if the system is still good and only minimal errors and you think it can be fixed ..so why don't you fix it. its more chalenging than reformatting.
In reformatting you lose important files to backup is very risky. so fix it.
Heres a challenge
Have you went into your programs and do a system restore to the day before you lost your drivers, You could also go into device manager and update your drivers I don't know if that will work or not, I know one thing if you format your Hdd you will loose everything and have to reinstall you operating system and drivers you will loose too. write back if that don't work and we will figure it out another way Ok, Thanks
