20 Most Recent Fujitsu LifeBook C2340 Notebook Questions & Answers
Harddrive password locked
Guess this site won't help stuck on "enter password " page Toshiba NB305-N410BN-G was given to me don't have password
8/2/2015 6:00:14 AM • Fujitsu LifeBook... • Answered on Aug 02, 2015
2answers
Lost Drivers Lifebook T4210
In order to download the drivers for your Lifebook, please visit Fujitsu's website listed here: http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADSOnce at the website, at the top of the screen, Select the following:Notebook PCT SeriesT4010Then Click Go. This will display all drivers for your Lifebook. I've included an image for reference.2_13_2013_11_21_35_pm.jpg
2/13/2013 11:21:53 PM • Fujitsu LifeBook... • Answered on Feb 13, 2013
Lifebook C2340 shuts off on its own
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
2/3/2013 1:56:31 AM • Fujitsu LifeBook... • Answered on Feb 03, 2013
My lifebook series c is a 2001 model that is wayyyyy to slow.
LOL, maybe you are low on disk space. Click Start/My Computer and right click on your local c drive to see how much space is available. If not much space is left that will certainly slow you down.Also if the hard drive needs to be defragged that will slow you down, but you've got to have enough space left (15%) to run a defrag.Also you might have a virus or infection that is slowing you down. So you might want to clean the computer by scans.Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
5/8/2012 3:38:30 PM • Fujitsu LifeBook... • Answered on May 08, 2012
How do I enable the touch pad on Fujitsu c series laptop
There should be a icon in the lower right corner where the taskbar is, the icon will resemble the actual touch pad, right click to make changes.
4/6/2012 7:22:11 AM • Fujitsu LifeBook... • Answered on Apr 06, 2012
How do I enable the touch pad on laptop Fujitsu C series
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.Hope this helps
4/5/2012 5:02:59 PM • Fujitsu LifeBook... • Answered on Apr 05, 2012
When i can download sound
You can download it here, just click on Audio.
9/5/2011 7:16:47 PM • Fujitsu LifeBook... • Answered on Sep 05, 2011
0answers
How can a revive a fujitsu life book c series
The first thing to do will be to try and recharge the battery because definitely that will be dead. After the battery has charged for a bit try powering the unit on and see if it functions fine (At this point it should if the unit was in good condition when it was dropped four years ago unless it was poorly stored).
Hope this solution has been helpful?
11/28/2010 7:10:23 PM • Fujitsu LifeBook... • Answered on Nov 28, 2010
I scanned my computer and it refuses to connect to
Let windows manage your network connections. This site shows you how:
http://oit.pdx.edu/use-windows-to-manage-wireless
7/31/2010 8:54:43 PM • Fujitsu LifeBook... • Answered on Jul 31, 2010
I can't download files attached to my emails.
log on towww.memoryupgrade.pro/4gb-fujitsu-lifebook
7/20/2010 9:22:42 AM • Fujitsu LifeBook... • Answered on Jul 20, 2010
My c-series fujitsu wireless enabled lifebook is
Now you just need to access the network gate address at your Fujitsu C2340 LifeBook C Series Notebook ,and open the wireless network function of the router.If you can't access in,it may be request a password,if you din't remenber,ask you friend how did he enter to the page.
5/31/2010 7:59:41 PM • Fujitsu LifeBook... • Answered on May 31, 2010
Keyborad won't work (but remote keyboard via USB port does)
Ok, first questuin, did you or somebody drop the computer or spilled any liquid on it?. The cause for a keyboard failure is very common in those two circumstances. If you spilled something on it and do not dare to take it apart, take to somebody who's specialized on such repairs to look at the problem and possible damage (computer technician most likely). If dropping it cause the problem, it may be a disconnected communication card. You have to take it apart and get to it and resecure it again by pressing it. You can find manuals online on how to disassemble it and get to it. Good luck.
1/10/2010 5:58:36 AM • Fujitsu LifeBook... • Answered on Jan 10, 2010
My Lifebook C2340 won't recognize it's own
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
12/16/2009 1:32:13 AM • Fujitsu LifeBook... • Answered on Dec 16, 2009
Fujitsu Lifebook C2340 will not read CD Drive
can you read any CDs at all? If not, try using a CD-ROM disc lens cleaner. if you can't do that, try a q-tip with some windex to lightly clean the DVD/CD lens. Use the other end of the q-tip to dry off any excess solvent.
10/7/2009 3:18:51 AM • Fujitsu LifeBook... • Answered on Oct 07, 2009
CD drive runs but the computer does not read it.
didu check if it on slave or master?cause sometimes thats the problem.....
10/7/2009 2:43:59 AM • Fujitsu LifeBook... • Answered on Oct 07, 2009
Song played in laptop tune is higher than normal
http://www.softwarepatch.com/utilities/ac97.html go to this side and download the realtek software and in stall in your pc it have all setting
9/22/2009 2:20:25 AM • Fujitsu LifeBook... • Answered on Sep 22, 2009
My laptop won't work and i've tried both of my batteries WU!!!
wow that sux. if the fujitsu won't turn on when plugged into ac; it is most likely your power supply. sadly it will have to be replaced
^_^
9/12/2009 8:18:19 PM • Fujitsu LifeBook... • Answered on Sep 12, 2009
Computers & Internet Logo
36 questions posted
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LifeBook Fujitsu
  • LifeBook Fujitsu
Most Popular Question
lost drivers lifebook t4210
  • Computers & Internet
