20 Most Recent Samsung UN46ES6100 46-inch LED TV Questions & Answers
Samsung 46 LED TV won't turn on
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/26/2015 1:13:53 PM • Samsung... • Answered on Feb 26, 2015
0answers
I WANT PASSWORD TV SHOWNIC TYPE LD-F42HS90 PLASE
2590,220184839
8/17/2016 2:53:29 AM • Samsung LE... • Answered on Aug 17, 2016
0answers
Le32b530
Be the first to answer 8/29/2015 10:47:23 PM • Samsung LE... • Posted on Aug 29, 2015Be the first to answer
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3/11/2015 1:46:13 PM • Samsung LE... • Answered on Mar 11, 2015
Television keeps clicking like it wants to turn on but doesn't come on. will come on ocassionally after a long wait
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
3/4/2015 7:33:18 AM • Samsung LE... • Answered on Mar 04, 2015
My tv has sound but the picture is white. Unable ti see the screen. Can see shadows. What is wrong with it? It's a samsung lcd
i need the model,but the problem is in the T-con board.
1/27/2015 5:34:52 PM • Samsung LE... • Answered on Jan 27, 2015
0answers
0answers
How to repair
Be the first to answer 8/17/2014 8:46:26 PM • Samsung LE... • Posted on Aug 17, 2014Be the first to answer
Samsung 46 inch keeps turning on and off immediately by itself
Most likely the power supply capacitors. you can identify them by their bulging tops.
7/24/2014 6:56:12 PM • Samsung LE... • Answered on Jul 24, 2014
0answers
0answers
0answers
0answers
LE40A676 t-con
Be the first to answer 5/23/2014 9:17:40 PM • Samsung LE... • Posted on May 23, 2014Be the first to answer
Samsung UN46ES6100 46-inch LED TV Logo
3 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
samsung 46 led tv turn
  • Televison & Video
