20 Most Recent
Fujitsu Siemens AMILO Pro V1000 Notebook Questions & Answers
I got Fujitsu Siemens AMILO pro V1000 laptop , the
A wireless hard drive? Wouha, you're lucky...
1. It's possible that the wireless adapter is disabled in the bios -> enable it.
2. Maybe it's only disabled in the device manager -> enable it.
3. It can be that the drivers for the adapter aren't installed -> install them.
Hope helps.
Dial up Modem
Dial up modems have 2 phone line connections side by side in the back of a desktop, one is for the wall, other is for your telephone. Laptops have just one phone line connector. Look closely at the little symbols by the connection holes. If you don't have one, Modems (internal or externally mounted), are on eBay, buy a 56K with drivers on disk for your operating system. A few modems can be installed using Windows default drivers (drivers are software operating programs that tell your computer how to regulate and operate a device).
Cant find my wireless conection on lap top
It doesn't show in Available Wireless Networks? If so, unplug the ISP modem, and the wireless device, Shut down the laptop, Check ALL cables and reseat, plug in the ISP modem, wait for selftest, plug in the wireless device, wait for selftest, boot the laptop. Open the Network Icon in the Tray Notification Area, do you see your wireless? Will it connect if you use a Ethernet cable? Post results
Four keys as g,h, backspace
SOLUTION FOR Four keys as g,h, backspace and windows key...:-
I read this on a website and it worked wonders for me. TRY THIS:-
1. Just remove the adapter so that your laptop does not get any power.
2. Let the battery go completely empty and let the laptop get shut down with low battery automatically.
3. After laptop gets shut down, remove the battery and clean it with some cloth. Also clean the battery panel.
4. Press and hold the power button for kind of 30 seconds or so (laptop will not get ON).
5. Plug in the adapter to the laptop and start the laptop normally.
This process will fix it for you.
If the above does not work:-
1. Start the computer in safe mode with the last best configuration. It may also work for you.
Thanks,
- Naveen
Cant find my sounddriver so
http://ts.fujitsu.com/support/downloads.html
go to
Laptops
then
Amilo pro
then
Amilo vxxx
then
Amilo v1000
then
xp drivers page after that
Some keys of keyboard of
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
When i switch on the laptop, all that happens is
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Hi
The ''N'' key has flipped
A fiddly job to do but is possible. The key that has come off will have a clip attachment underneath, you need to remove it and fit it to the clips on the keyboard first. It will be in an X configuration so you need 2 very small screwdrivers (jewellers ones work well) to lift the "X" once connected to the keyboard and connect to one side of the key button.Once done on one side remove the screwdrivers and press down on the key button to click the other side in place.
I can't think of a better way to describe it. One of those " easy if you know how" things.
Fujitsu Siemens Amilo - Won't boot
could be hard drive failure,or you might try to reinstall windows before bying a new hardrive,but before any of that go to the BIOS and make sure that the boot order is right usualy hard drive first
My Fujitsu touchpad is crossed showing it to be
hi,
you can unlock or lock the keypad of your notepad by pressing the "fn" key and F7 key simultaneously. In some versions this feature is changed to "fn + F6" keys. please check the symbol on the keys from (F4-F7), where you can find the symbol of "hand on pad". press fn and that particular key simultaneously to unlock your touchpad! i have shown the picture of another laptop. please observe the F7 key in that picture given below. you can see the symbol i specified. hope this is helpful. Please rate my solution as helpful.
