20 Most Recent
Westinghouse 40" 1080P Lcd Hdtv Questions & Answers
Wont power inverterit has power to the wall to the power board but the tv wont turn
google the manufacturer and model number and the words "bad capacitor" or "replace capacitor" and see if someone has photos of a retrofit for broken capacitors. You need to know your way around a soldering iron but there are hundreds of computers and flat screens that got bad capacitors installed. For someone who knows how to solder they can look at a photo with the bad capacitors circled, check their own product, pull the bad capacitors, replace and have a great TV again. I did this with a Sceptre Naga 3.
There was one year when perhaps 1/5th of the capacitors made were bad (one factory in china). Lots of manufacturers knew that they had problems but shipped anyway. At least one computer manufacturer has been successfully sued on this.
Tv keeps cutting
hi this could be a capactior in the power supply they usually bulge up causing faults like this,look for a tech in your area good luck
regards
shaun
Tv keeps blinking
hi this sounds like a power supply fault, could be capacitors you will need tech to check it
regards
shaun ,
Power went out now westinghouse tv wont work
The brown outs created by your AC unit may have caused some internal damage to the Power board or the inverter board. If you aren't able to do the basic electronic dignostics required, take it to a professional to have it diagnosed. If you're handy and able to do some basic diagnostics with a VOM, remove the back of the TV and look for bulging capacitors or check for possibly blown fuses with an Ohm meter.
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
- Press the power button on your TV to turn it on.
- Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
- Look for the "Reset" option and select it.
- Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
- Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
