20 Most Recent Westinghouse LD-4055 40 Class LED HDTV -1080p, 1920 x 1080, 16:9, 4000 Questions & Answers
How to turn off speakers
turning off loud speaker bt6500
5/21/2014 4:42:15 PM • Westinghouse... • Answered on May 21, 2014
My Westinghouse LD4055 makes a weird sound when
lg tv model 21fj8rg3t8H OUT (2) folister capasiter valu
9/7/2013 7:30:33 AM • Westinghouse... • Answered on Sep 07, 2013
0answers
Is the westinghouse LED TV LD 4055 ARC compatible?
I don't believe it is. Westinghouse mention nothing about it in the Manual. However, whether it is or not, it won't make a difference in the sound system you buy. If you get your cable feed from the TV's tuner you can connect the Digital Coaxial output from the TV to your new HT receiver.
10/31/2012 5:28:20 AM • Westinghouse... • Answered on Oct 31, 2012
Missed the screws
4mm diameter by 7mm long screws avail @Lowes in special fastener section
5/28/2012 11:26:36 PM • Westinghouse... • Answered on May 28, 2012
2answers
How to obtain code for ATSC tuner activation for westinghouse LD2240
  1. activation code 6160y04401296
3/20/2024 3:26:41 PM • Westinghouse... • Answered on Mar 20, 2024
2answers
Cual es el codigo de acceso para canales de tv LD-2240
C?digo de acceso para tv westinghouse, modelo LD-2240 , num de serie :6610120103391
2/25/2024 8:34:27 PM • Westinghouse... • Answered on Feb 25, 2024
3answers
I need the 5-digit code for a Westinghouse TV
This code worked for me Code: 31415
1/12/2024 1:24:52 AM • Westinghouse... • Answered on Jan 12, 2024
2answers
Can I get codes that can reset my old Westinghouse smart tv
Yes, you can reset your old Westinghouse smart TV by using reset codes. The specific code you need may vary depending on the model of your TV. Here are some general steps you can follow to reset your Westinghouse smart TV using reset codes:
  1. Press the power button on your TV to turn it on.
  2. Using your TV remote, press the "Menu" button and navigate to the "Setup" or "Settings" menu.
  3. Look for the "Reset" option and select it.
  4. Enter the reset code for your TV when prompted. The reset code may be a sequence of numbers or a combination of buttons on the remote control.
  5. Follow the on-screen instructions to complete the reset process.
If you don't know the reset code for your Westinghouse smart TV, you can usually find it in the user manual or by contacting Westinghouse customer support. Keep in mind that resetting your TV will erase all custom settings and restore the TV to its factory default settings
1/6/2024 10:03:36 PM • Westinghouse... • Answered on Jan 06, 2024
Westinghouse Television Code. I am trying to get a activation code for my Westinghouse tv remote.
The are two types of code. One to activate the television, or a Universal remote code. FYI, no one uses Universal Remotes in 2023/2024. https://www.google.com/search?q=activation+code+for+westinghouse+tv+remote https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/30/2023 8:16:26 PM • Westinghouse... • Answered on Dec 30, 2023
Necesito codigo de tv westinghouse modelo vr4030 para programar canales digitales
necesito. C?digo. De. Acceso. Para. Tv. Westinghouse. Modelo. Uw40t3pw. Serie. 6590y21603173
12/1/2023 12:39:38 AM • Westinghouse... • Answered on Dec 01, 2023
Would like to know what the code is to program my GE universal remote to my 2008 Westinghouse model number ltv-37w2hd
Be sure to manually turn on the device you wish to control. Press. And hold the setup button until the red indicator light remains on and then release the button. Press.
11/1/2023 6:08:28 AM • Westinghouse... • Answered on Nov 01, 2023
Looking for a replacement interior or complete panel for a Westinghouse Cat. NO B20 1632CGT Panel
Only 1 left!
Westinghouse B20 1632CG 200 Amp 120/240V 1 Phase 3 ...
S&S Electrical Supply https://www.sselectricalsupply.com > en-ca > products Westinghouse B20 1632CG 200 Amp 120/240V 1 Phase 3 Wire Indoor Enclosure 22 Space 28" x 15". Save 0. Westinghouse. filler. 1 In Stock / 0 Sold. Style: Used.
10/30/2023 12:05:10 AM • Westinghouse... • Answered on Oct 30, 2023
How do you reset a westinghouse tv?
You can refer to this blog post. It is in detail and very helpful. https://smarthomehut.com/how-to-reset-westinghouse-tv/
4/8/2023 9:37:24 PM • Westinghouse... • Answered on Apr 08, 2023
Half of screen darker on Westinghouse tv
A model would have been beneficial, guessing you have half the LED strips not lighting but it's just a guess without the model
3/29/2023 9:49:43 PM • Westinghouse... • Answered on Mar 29, 2023
5answers
I need a channel access code for a Westinghouse model VR5535Z
try this... Contact westinghouse Channel Access Service by: web: www.westinghousedigital.com/support; select Channel Access and enter Access info. Text Message: Text Tuner to 95495 Phone:1-800-701-0680 follow instructions
2/19/2023 1:45:41 AM • Westinghouse... • Answered on Feb 19, 2023
2answers
Westinghouse WD55UW4620 no picture
Before you replace the power board, there are a few things you can try to troubleshoot the issue with your Westinghouse WD55UW4620 TV:
  1. Adjust the picture settings: It's possible that the picture settings on your TV have been accidentally adjusted, resulting in a dark picture. Try going into the TV's menu and adjusting the brightness, contrast, and other picture settings to see if that helps.
  2. Check the backlight: The backlight is responsible for illuminating the pixels on your TV screen, and if it's not working properly, it can result in a dark or dim picture. You can check the backlight by shining a flashlight on the screen and seeing if you can make out any images. If you can see images, then the backlight is likely the issue.
  3. Check the cables: Make sure that all the cables connecting your TV to external devices are securely plugged in and not damaged.
If none of these troubleshooting steps work, then it's possible that the power board is the issue. In that case, replacing the power board may fix the problem.
2/16/2023 1:04:55 AM • Westinghouse... • Answered on Feb 16, 2023
Backlights on Westinghouse WD50UC4300 TV flash and then go out.
It's possible that there is a problem with the protection circuit, especially if the backlights are receiving the correct voltage but are still not functioning properly. You could try checking the fuses or diodes on the circuit board that are responsible for protecting the backlights. It's also possible that there is a problem with the power supply or the main board that is causing the issue. If you're not comfortable working with electronics, it may be best to consult a professional for assistance.
2/14/2023 3:15:45 AM • Westinghouse... • Answered on Feb 14, 2023
Westinghouse LD-4055 40 Class LED HDTV -1080p, 1920 x 1080, 16:9, 4000 Logo
Popular Tags
11 questions posted
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
westinghouse led tv ld 4055 arc
  • Televison & Video
