20 Most Recent
Contax NX 35mm SLR Camera Questions & Answers
My Contax NX started flashing "EEEE" this
I am sorry to hear regarding the trouble. This is a common problem with Contax and has been discussed in many forums and blogs.
This display means that there is an error in the system and it points towards an issue with the shutter. Unfortunately, the only option is to send the unit for repair so that they could replace the shutter. This is an ongoing issue with most of the models and it's really sad to see one more client having the same issue. On few occasions, changing or pulling out the batteries might help, however if you have tried that - the only option is to send the unit for repair.
I wish i could have a better solution.
Kindly accept the solution so that i could get the credit for my time.
Thanks and Regards
taran_2005
Talked to two experts yesterday - the first one
First, try removing the batteries and then reinstalling them. If the problem persists, you may wish to try a new battery. If this doesn't solve the problem, you will need to send this camera in for repairs. Parts for this camera are hard to find so you will want to have an experienced Contax repair company to repair your camera, like TOCAD.
TOCAD is the only repair company for Contax in the United States that I know of. Here is there site:
http://www.tocad.com/ I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Please help - urgent!! I
The auto-rewind is triggered when the film advance mechanism detects tension on the film, indicating the end of the roll.
moisture can cause it to stick.
If it has done this with various rolls of film, it is likely that the clutch mechanism that detects the film tension is out of adjustment. This is something that a professional camera repair shop will need to fix.
robert
11/29/2009 7:21:12 AM •
Contax...
Answered
on Nov 29, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
Driver for target australia film scanner f100
I own the Target AU F100 film scanner and have the original CD. It has a Driver directory on it, which includes DriverInstaller app and 32 and 64 bit subdirectories. It installed recently on my Win 10 64 bit PC and worked ok, despite being Win XP/Vista software vintage 2010.
6/14/2023 3:09:06 AM •
Photography
Answered
on Jun 14, 2023
