20 Most Recent
Gateway MS-6389 Ver.1 S462 Motherboard (4000758) Questions & Answers
Just bought a new motherboard and have hooked it
1. You may have a power supply issue.
2. Try removing the power supply and replacing it with a know good one with the same specifications.
3. the power supply is giving the +12 volt to the fans but not to the rest of the board.
Drivers for MS-6389 Ver.1
Is it a Gateway PC?. They seem to be the only ones that use that motherboard.
If so have a look on their website.
You will need PC model or serial number.
http://support.gateway.com/support/drivers/ddaStep.asp?pg=2&Tab=All
Computer restarting
Your hardware can be a cause of your issue , ( A.K.A bad DVD-Rom , power supply or even the hard drive ) Or the Opertional System is corrupted ( A.K.A Windows XP , WindowsVista , Linspire 6.0 or RedHat Linux )
Unable to Power Motherboard
Try to jump start it with a screwdriver, just touch the screwdriver to the place where the power connection (from the front) cable plugs in. If this works, you need to plug the power into there, if not, you may not be hitting the right spot, or the psu/mobo is bad.
Motherboard Manual for MS-6389 Ver.1 S462 Motherboard
This is the closest manual I could find for this motherboard. The link below will lead you to download a manual for the MS-6380LE (the other models close to this were MS-6378 and MS-6390)
However, it shouldn't be too different.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=287
Please let me know if you still have problem with connection.
Thanks,
Lolita
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
