20 Most Recent
Gateway 7405GX Notebook Questions & Answers
Gateway 7405gx Integrated Wireless - How do I check BIOS?
When booting you hit the F2 or Delete button. Keep in mind that the Fn Button might have to be held down at the same time as you clicking the F2 button.
Timing is also key start tapping the F2 before you even hit the power button.
Factory restore
If you have the recovery disks for you computer insert them into the CD/DVD ROM and follow the on screen wizards. If not then you have to order a recovery Drive from Gateway or you can download the ISO image of desired operating system and burn it on a DVD and then do a clean install. Afterwards download the required driver from gateway.
My dell inspiron 6400 no power at all
If your battery is charging, then i guess it is suffering from Dells Graphics card known issue. Basically the graphics card stops working which also wont let your laptop boot up. A tell tale sign of this being the problem is when you press the power button on your laptop, the power light will flash on for a second then die.... hope this helps...
Keyboard replacement
Did you look at the gateway site for the manual? It should be in it. That is what I always do.
I lost the software for
You can download it from
HERE. On the download page, simply click the name of the driver/s to download. Download both Chipset and VGA drivers and install them. Let me know if you have problem.
Good Luck.
Thanks for using
FixYa.
My Gateway 7405 randomly shuts down. It does not
You might try changing the Power Options (its
in the Control Panel) Properties so that all windows are set to NEVER.
That is, so that it will never automatically turn off monitor, hard
disks or go to standby. Also turn off all the alarms.
This worked for my Presario R3000 running WinXP Sp2 which would shut off for no apparent
reason.
Having said that, you should blow out your fan with compressed air
occasionally. And check that your power cord is OK. When you pull out
your power cord, the battery icon should show operation.
Gateway 7405gx laptop will not load windows .goes
There is problem on the user account, or the hard drive. Try login as administrator. If the problem still occurs you need to reformat your laptop or try the recovery disk or option of your laptop. Or try changing the hard drive. But still, you need to re-install or try the recovery option or the disk.
Gateway 7426 GX shuts down randomly after fan revs
This seems to be a motherboard related issue. I am having the same problems. Some speculate that it is something to do with the cpu throttling causing the cpu to think it's going to overheat and so it shuts off. Others think it's a faulty cpu temp sensor. If you keep the laptop idle (no intense video applications), then it won't do it, but that makes it very useless. Also, make sure both fans work as the system has 2 inside. One seized and ruined one 7426 on me so I got another for cheap and now it's happening.
