20 Most Recent
Panasonic UF-5500 Fax Machine Questions & Answers
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
11/30/2015 2:28:53 PM •
Panasonic...
Answered
on Nov 30, 2015
Panasonic cf-19 Enter key not working
- Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM •
Panasonic...
Answered
on Jun 16, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM •
Panasonic...
Answered
on Apr 01, 2023
Panasonic cn-mw100d will not turn on but power is coming to unit
The Panasonic CN-MW100D is a portable navigation device. If it's not turning on even though power is coming to the unit, it could be caused by a few different things.
- First, check that the power cord is securely plugged into both the device and the power source.
- Second, check the battery level, if the device has a battery, if the battery is dead, replace the battery or charge it.
- Third, check the fuse, if the fuse is blown, replace the fuse.
- Fourth, try doing a hard reset by holding down the power button for 10 seconds.
- If none of the above steps resolve the issue, then the problem may be with the internal hardware of the device and it may need to be repaired or replaced.
1/31/2023 8:29:42 PM •
Panasonic...
Answered
on Jan 31, 2023
