These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
I would send it in for repair. If there are 3 contact pins when there should be 4, you will need that part that holds the pins. It is unusual to have a Service manual for cameras, but here it is and shows disassembly.
https://www.google.com/search?q=panasonic+lumix+fz28+repair+manual
Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
The usual cause is leaky line output stage or transformer.
Lift the line output transistor out and see if the voltage rises. If it does, scrap the TV as it is totally obsolete.
If it doesn't, repair the power supply, if you can source the obsolete parts.
All the codes are here
https://codesforuniversalremotes.com/remote-control-codes-for-panasonic-tvs/
But.....
Universal Remotes? No! What is a Facsimile Remote?
Your television or other device remote control fails and you think "I'll have to get a Universal Remote". In reality, no one buys universal remotes these days. They are so far back in the 1980s! You buy a 'facsimile remote' which is exactly the same as the original and requires no programming. Very often they are the same shape and the same button layout, so there is no learning transition. Google;
make model (of television) replacement remote
You will find somewhere like this
https://www.remotecontrols.com/
or
https://www.remotes.com/
For those that still want universal remote codes, the make of the universal remote is irrelevant, you only need the television make, as the codes are universal by maker. This link will find you the best websites for codes.
https://www.google.com/search?q=universal+remote+codes
Posted by ADMIN... on May 03, 2022
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
The likely cause of this message is a defective memory card or a corrupt file on it. Try replacing the memory card or reformatting it, and then restarting the machine. If that does not resolve the issue, contact the manufacturer for assistance.
The Panasonic CN-MW100D is a portable navigation device. If it's not turning on even though power is coming to the unit, it could be caused by a few different things.
First, check that the power cord is securely plugged into both the device and the power source.
Second, check the battery level, if the device has a battery, if the battery is dead, replace the battery or charge it.
Third, check the fuse, if the fuse is blown, replace the fuse.
Fourth, try doing a hard reset by holding down the power button for 10 seconds.
If none of the above steps resolve the issue, then the problem may be with the internal hardware of the device and it may need to be repaired or replaced.
