20 Most Recent
Honeywell DOLPHIN 6500:5300SR IMGR/28KY 128X128MB/80211BG/BATT/PS/BT Questions & Answers
Re phone BT6500, how does one increase the number of rings before it goes to answerphone?
Hi
I give below the step by step procedure for changing the number of rings the phone will sound.
1. Select Menu, Answer Phone is displayed, press
Select.
2. Press until Settings is displayed, press Select.
3. Press to highlight either Ans. & record or
Answer only and press Select.
4. Answer delay is displayed, use or to display
the number of rings you want (0-9 rings or Time
saver) and select Save. Saved will be displayed.
Be aware though that the number of rings needs to be less than your ansaphone service, for BT 1571 this is 5 rings, although more may be possible if you can get BT to change their 1571 for your line.
For more information about your phone you can download a pdf format manual from here:
https://www.shop.bt.com/content/uni2/documentation/8h3j/bt6500_user_guide.pdf
This can be saved to hard disk for future reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
12/11/2014 8:52:05 PM •
Honeywell...
Answered
on Dec 11, 2014
My Honeywell plug-in doorbell won't stop ringing
If your Honeywell plug-in doorbell won't stop ringing, there are a few things you can try to troubleshoot the issue:
1. Check the batteries: If your doorbell has batteries, make sure they are properly installed and have enough power. Replace them with new ones if needed.
2. Check the ring options: Press the ring option button with the music sign and cycle through the different ring options until you find one that stops the ringing.
3. Reset the doorbell: To reset the doorbell, unplug it from the wall outlet and wait for a few minutes before plugging it back in. This will allow the doorbell to reset and may solve the issue.
4. Check the chime settings: If your doorbell has multiple chime options, make sure the one that's causing the issue is not selected. You can cycle through the chime options using the settings button.
5. Contact customer support: If none of the above steps work, contact Honeywell customer support for further assistance. They may be able to provide additional troubleshooting steps or offer a replacement if the doorbell is defective.
2/22/2023 10:53:48 AM •
Honeywell...
Answered
on Feb 22, 2023
