20 Most Recent
IBM ThinkPad Soundcard Questions & Answers
Where do you install the sound card?
It's tiny chip embedded on the motherboard. Nothing you can do. Here are you drivers. Just in case. http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ga241ww.exe
Hi plz help me i
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
I'm not getting any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
First make sure sound driver installed and working fien make sure sound is not muted and not low volume. Then uninstall sound driver from device manager and control panel.
Then download driver from below link and install then check.
Select os and model then download and install.
Click here
Let me know if you need further assistance.
Thanks for using FixYa.
I reformatted my IBM laptop,
once you have reformatted and reinstalled your operating sytem you have to set up the sound system again
also
hope this helps you
When I open Skype and
open skype go to tools from the drop down list select options scroll to audio settings you can make a free test call before you try to make a call make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
There no sound in the
also
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Although I have tried to
Janis,
Give me the model number of your computer and what version of Windows you are running and I will run down your system and advise you accordingly. I am going to look at your past post to see if I can get any ideas from there but, let me know at "add a comment" at the botom of the solution.
Dave
No sound
First right click my computer then click properties then hardware then device manager and expand the sound video and game controller and see if the driver is marked with yellow question mark or marked with red X then you will have to reload the drivers and if you dont see any audio drivers then switch of the computer press del and enter bios and enable the audio device then click the volume control in theoolbar and check wether mute is clicked if clicked remove them and adjust volume slider to high
The speakers were working two weeks ago now i get
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
No sound
if you are having problems
with your sound
settings there
also
icon in taskbar
problem
connection is good
hope this helps
No sound on my thinkpad
settings there
also
icon in taskbar
problem
connection is good
hope this helps
Multimedia audio controller
try the lenovo website who have taken over IBMs thinkpad range, their support is usualy good and contains most drivers
ThingPad T40 kein Sound
Try downloading the latest audio driver.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver.
When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive.
Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
