20 Most Recent
Westell Wirespeed Westell Dsl Router Wind River C90-610030-06 Questions & Answers
Modem installation
It is not a lost cause BUT you will have major issues connecting to most websites because the browsers are so advanced now that if you connect, it wont display correctly and there is an issue with some secure servers rejecting you because the operating system can be read and the server wont allow the connection.
http://www.dslreports.com/faq/bellsouth/3.14_Westell_2100_2200_6100_Info#7342
7/26/2017 1:06:12 AM •
Westell...
Answered
on Jul 26, 2017
Where ca i find it's drivers
I dont think u can that looks like its box u get from a company provider.. Netgear bought out westell and u can look there for something..
9/5/2012 6:47:36 PM •
Westell...
Answered
on Sep 05, 2012
I need to change the password on my verizon router I do not have verizon internet can you please help me ?
It is clear you have not setup encryption within the router. You need to access your router, go into the router setup and setup security normal wpa2 or wep pending your computers and operating system in use. It will ask you for a secret passkey to enter. Without having this setup any one can cannot to your wireless router. But once the passkey has been setup only you will be able to access it. Very easy fix. if your do not know how to access your router control follow the instruction manual that cam with it, it is normally well explained or just contact me again. regards Hands of Time.
8/2/2014 12:11:44 PM •
Westell...
Answered
on Aug 02, 2014
How do I reset the password for my router ?
At the back of your router there is a small pinhole with the word "reset" printed just below the pinhole. Use a paperclip push it softly into the pinhole until you feel it makes contact with this switch, press in and hold for 3 to 5 seconds. That will do the trick. Cheers HoT.
8/2/2014 12:06:54 PM •
Westell...
Answered
on Aug 02, 2014
Forgot ssid password
Where are you entering it? (In the router it should be) and simply enter "change password" you will then need to enter this new P/W into your laptop / PDA / iPhone etc.
5/24/2014 9:20:00 PM •
Westell...
Answered
on May 24, 2014
What is my SSID #
The SSID is the router's wireless network name.Network security keySome later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop. If these settings do not suit you, then it can be changed to suit yourrequirements. The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.
http://www.fixya.com/support/r10267861-network_security_key
4/28/2012 11:06:22 AM •
Westell...
Answered
on Apr 28, 2012
I'm trying too install the
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
8/26/2010 6:25:16 PM •
Westell...
Answered
on Aug 26, 2010
How can I configure Dynamic
First connect your router to computer with ethernet lan cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip and gateway ip is your router ip access router with it.
Then it ask for user and password.
Type user as "admin" and password as "admin" orblank or "password"
Then configure DNS settings in wan settings as dns ip get automatic from internet service provider.
Then save settings and restart router.
8/13/2010 8:12:25 PM •
Westell...
Answered
on Aug 13, 2010
