20 Most Recent Smeg 24 in. DWF612WH Free-standing Dishwasher Questions & Answers
0answers
My SMEG Dishwasher is not cleaning my dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101 75osrha
9/29/2010 4:00:33 PM • Smeg 24 in.... • Answered on Sep 29, 2010
Took out filter to clean noticed water in tank
yes....most leave a little behind as the pump out hose is higher than the pump..
7/20/2010 7:30:49 PM • Smeg 24 in.... • Answered on Jul 20, 2010
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
2/1/2008 4:56:46 PM • Smeg 24 in.... • Answered on Feb 01, 2008
How to remove the drain hose from a SMEG DWAU6214X Dishwasher?
Pull it out and tip it on its front and you should be able to work from underneath, or remove the side panel. This appears to be an Australian model. We are in North America, so this link should work better for you. https://www.google.com/search?q=smeg+dwau6214x+drain+hose+replacement ..
1/22/2024 7:53:37 PM • Smeg Dishwashers • Answered on Jan 22, 2024
My SMEG dishwasher model D16012 is not filling with water, nothing happening
Question moved from Cars and Trucks category. It may be that the water inlet valve that has failed, but it could also be that the main control board has failed. Due to the cost of boards, I would suggest you get professional diagnosis from a Smeg technician.
10/14/2023 1:20:49 AM • Smeg Dishwashers • Answered on Oct 14, 2023
Smeg Dishwasher stops and message is "Err"
https://www.hunker.com/13408989/how-to-reset-a-smeg-dishwasher It must be the open and close Quickly that makes this work.
6/30/2023 10:55:24 PM • Smeg Dishwashers • Answered on Jun 30, 2023
2answers
Smeg dishwasher will only wash top drawer
Check the options on the door of dishwasher. Some dishwashers allow you to select wash top rack or bottom or both. Check your settings.
2/6/2023 4:23:45 AM • Smeg Dishwashers • Answered on Feb 06, 2023
SMEG DI612E Dishwasher not working, 5th LED flashing.
Page 39 and 40 (page numbers, not site numbering) of the manual has your flash codes, but your flashing doesn't exist. Try a reset, disconnect from the mains overnight. If that doesn't fix it, you need a service call. https://www.manuals.ca/smeg/di612e/manual?p=41 ..
8/18/2022 3:22:19 AM • Smeg Dishwashers • Answered on Aug 18, 2022
Smeg dishwasher displaying Er01 code
This is a possible problem with either the switch that prevents the washer over filling with water during a wash cycle or there is a leak in one of the pipes inside the machine. I would recommend you get an engineeer to look at it as you will need to get inside the machine to repair this.
3/21/2022 10:23:28 AM • Smeg Dishwashers • Answered on Mar 21, 2022
What does error code 01 indicate?
Water could be leaking under the door as a result of sealing tape failure.
3/12/2022 10:22:16 PM • Smeg Dishwashers • Answered on Mar 12, 2022
Why does the spray arm keeps falling off?
Hi, I've got the same problem here - i made a video of it too (https://youtu.be/SzlIP6iArvs) - I hope you can solve my problem. Thanks.
2/3/2022 1:43:02 PM • Smeg Dishwashers • Answered on Feb 03, 2022
3answers
Hello. I have an error 24 on my smeg dishwasher,model cw511mdaus-2. what is the error?how to reset machine,thank you. cheers Andrew
This is a commercial unit it error codes are different Er 24 Boiler temperature probe Boiler temperature probe disconnected or not working malfunction this is in the user manual
8/30/2021 7:47:08 PM • Smeg Dishwashers • Answered on Aug 30, 2021
E3 Error
the E3 error is a result of water temperature not getting to a nominal value within a particular time. This could be caused by several factors like heater faulty, wash pump not working well, wash arms not circulating water as required. Need model number to help you further pin point if possible. Refer this site for 60 inch dishwasher and this site for 45 inch ones.
2/4/2020 8:25:35 PM • Smeg Dishwashers • Answered on Feb 04, 2020
Smeg 24 in. DWF612WH Free-standing Dishwasher Logo
18 questions posted
Top Smeg Dishwashers Experts
Mike Cairns
Mike Cairns
Stan Ford
Tracy
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Smeg Dishwashers
  • Smeg Dishwashers
Most Popular Question
smeg dishwasher not cleaning dishes
  • Dishwashers
