20 Most Recent
IBM Thinkpad T30 Notebook Questions & Answers
My Ibm is T30 the when i put jack power the
Hello there:
here are the hints or ideas
1) You may have a bad or damage, power on connector (soldering) inside the motherboard.
2) Bad Charger , you need to check these with a multimeter, if you know how to do it.
3) bad video inverter or its starting to fail.
4) or simply your video card, is failing. perhaps dust, or the fan for the video card is bad or clog .
Good Luck
Carl
Need wireless connection driver
it should be on your recovery disk that came with computer when it was bought new if you dont have that disk try windows update to fine it
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
How do i connect to a printer
Hi Jenelle
I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi).
in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly.
press the identify now button after connecting it with USB.
HP Support Software Drivers
