IBM ThinkPad T20 2647 PC Notebook
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with IBM ThinkPad T20 2647 PC Notebook?
Troubleshooting and Support
Solved Problems for IBM ThinkPad T20 2647 PC Notebook RSS Feed Post a New Problem
T42 Turns on for a split second then turns...
Good evening, Yesterday my IBM T42 unexpectedly turned itself off. Since then every time I try to turn it on it...
1 Solution
PC CHIP Motherboard
good day, I have 2 PC Chips and MSI motherboard which colud power but no post screen nor beep, every thing remain dead...
1 Solution
thinkpad t20 trouble installing operating...
computer chased and windows would not run so i assumed it was the hard drive. i replaced the hard drive and tried to...
1 Solution
IBM Thinkpad 770
Hi,I have a IBM Thinkpad 770 and when I try to in stall windows xp it runs 100% on first bar and when it goes to fine...
1 Solution
I don't know if the think pad has an...
Do I have to purchase a modem for the think pad? I am illiterate when it comes to computers. I thought I just had to...
1 Solution
need driver for 8x dvd drive for thinkpad
looking for the drivers for dvd-rom sd-c2512 for the t20 windows xp
1 Solution
Blue Button under right and left button on...
I can not find the setting for the blue button on the laptop...i had one setting in which i really liked and then it...
1 Solution
Unsolved Support Problems
Unsolved Problems for IBM ThinkPad T20 2647 PC Notebook RSS Feed Post a New Problem
thinkpad T20 won't recognize usb port
My thinkpad T20 will not recognize the usb port. I need it for my pc internet. I know the port is getting power, it just...
Post a Solution
windows not starting up
i have ibm laptop think pad.windows could not start because of a computer disk configuration problem.Coold not read from...
Post a Solution
0175: bad crc1, stop post task, system...
0175: bad crc1, stop post task system bios shadowed video bios shadowed
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Operating SystemMicrosoft Windows 98 SE · Microsoft Windows 2000
ProcessorIntel Pentium III 700 MHz · Intel Pentium III 650 MHz
Installed Memory128 MB (SDRAM)
Recommended UseCorporate Business, Small Business · Corporate Business
Display14.1 in. TFT Active Matrix · 13.3 in. TFT Active Matrix · 13.3 in. XGA TFT LCD
Processor
Processor TypePentium III
Processor Speed700 MHz · 650 MHz
Processor ManufacturerIntel
Motherboard
Bus Speed100 MHz
ChipsetIntel 440MX
Display
Display Size13.3 In. · 14.1 in.
Display TechTFT Active Matrix · XGA TFT LCD
Display Max. Resolution1024 x 768
Display Color Support24-bit (16.7 million colors)
Technical Features
Expandability2 x Type I/II PC Card Slot, Docking Station/Port Replicator
Security FeaturesHDD Password, Power-On Password, Administrator Password, IBM Security Slot
Expansion PortsVGA out, Serial Port, PS/2 Port, RJ-11 (modem), RJ-45 (NIC), S-Video out · 1 x USB 1.1, VGA out, Parallel Port, Serial Port, RJ-11 (modem), RJ-45 (NIC)
Hard Drive
Hard Drive Capacity6 GB · 12 GB
Storage Controller TypeIDE
Memory
RAM TechnologySDRAM
Installed RAM128 MB
Installed Cache Memory128 KB · 256 KB
Max Supported RAM512 MB
RAM Speed100 MHz
CD / DVD
Optical Drive Read Speed24x (CD) · 6x (DVD)
CD / DVD TypeCD-ROM · DVD-ROM
Other Drives
Floppy Drive3.5" 1.44 MB floppy
Video
Installed Video Memory8 MB
Graphic ProcessorATI MOBILITY RADEON 7500 · S3 Savage IX8+
External Video Resolution1600 x 1200
Graphic Bus InterfaceAGP x2
Audio
Audio Output TypeSound Card
Audio Input TypeMicrophone · Line In
Modem
Modem TypeFax / Modem · Network / Modem Combo
Analog Modulation ProtocolITU V.32 · ITU V.90 · ITU V.34 · K56Flex · ITU V.34bis · ITU V.17 · ITU V.22bis · ITU V.32bis · ITU V.21 · ITU V.22 · ITU V.27ter · ITU V.29
Battery
Battery TechnologyLithium ion
Battery Run Time4 Hour(s). · 3 Hour(s).
Warranty
Warranty3 Years
Networking
Data Link ProtocolEthernet · Fast Ethernet
Networking TypeIntegrated 10/100 · Integrated Network Card
Dimensions
Depth9.65 in.
Height1.3 in.
Width12.02 in.
Weight5.29 lb.
Supported Models
264721U, 264724U, 264731U, 264741U, 264744U, 264746U, 264761U, 264781U, 264784U, 264786U
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
Loading problems.
Top PC Laptop Experts
Pyrhyc
57 solutions
PC Laptops, Computer Components
Ask Me
Guru
harveste
9 solutions
PC Desktops, PC Laptops
Ask Me
Wiz
shaggy24
5 solutions
Monitors, PC Laptops, Routers, PDAs
Ask Me
Wiz
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
