20 Most Recent IBM ThinkPad T41p Notebook Questions & Answers
You might have some viruses and malware..
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
IBM ThinkPad... | Answered on Jul 21, 2012
You have to install the latest drivers from think pad support website, it solved my problem before. Driver for your VGA card
IBM ThinkPad... | Answered on May 18, 2012
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
if you can start task manager click new task and type explorer.exe you may need to do it more than once.
IBM ThinkPad... | Answered on Feb 26, 2011
if you entered your serial number during installation of windows just activate online or call microsoft to activate, if you didnt enter your serial number its located on teh bottom of your laptop.
IBM ThinkPad... | Answered on Mar 25, 2010
CPU fan, right? The fan is actually under the keyboard. There are 4 screws at the bottom of the case, labelled with a keyboard symbol. Once unscrewed, press the top of the keyboard (where the power/volume buttons are) downwards (i.e. in towards the palmrest) to free the keyboard. Then carefully disconnect keyboard connector. Once the keyboard has been removed, you should be able to remove the cpu heatsink. The fan is attached to the heatsink, to remove it just undo the screws holding it.
Hope this helps,
Good luck,
Raf
IBM ThinkPad... | Answered on Nov 14, 2009
NO it may be you are have LCD problems try an external monitor if tht goes alrite that the latte is the problem.
IBM ThinkPad... | Answered on Sep 25, 2007
Go to control panel select region and languages. Choose your preferred language.
IBM ThinkPad... | Answered on Aug 27, 2019
Run a FULL virus scan and a FULL Malware Scan. Use the free version of MalwareBytes Anti-Malware.
Windows 7 scroll bars automatically moving Windows 7
video
my mouse scroll up and down automatically 2 way to fix
and test keyboard program
Windows 10 Scrolling Issue Problem Solved
Scrollbar moves down automatically Google Search
IBM ThinkPad... | Answered on Dec 30, 2017
hi have a look at this pdf it shows you everything inside your comp;
also it could be a driver issue for you video card
https://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6189.pdf
IBM ThinkPad... | Answered on Nov 01, 2017
Hi Jenelle
I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi).
in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly.
press the identify now button after connecting it with USB.
HP Support Software Drivers
IBM ThinkPad... | Answered on May 23, 2016
If you set the boot sequence to hdd then if the hdd is bootable, it will boot unless the hdd is faulty. Same applies for other drives.
IBM ThinkPad... | Answered on Mar 13, 2016
If it is the windows password, there are people that you can take it to for a repair. Ask at your local pc repair store.
IBM ThinkPad... | Answered on Mar 10, 2016
If the hdd password is lost, purchase a new hdd and instal your backups to it. The password is a security item and not recoverable.
IBM ThinkPad... | Answered on Mar 09, 2016
If it is the whole's computer language, you have to re-install the operating system, but get a copy that is in english language.
IBM ThinkPad T41p Notebook Logo
20 questions posted
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad IBM
  • ThinkPad IBM
Most Popular Question
projecctos not connecting
  • Computers & Internet
