20 Most Recent
IBM ThinkPad T21 2647 Notebook Questions & Answers
Forgot boot password t21
Which password are you talking about? Windows, BIOS, hard drive? Anyways all of these can be reset with the hiren boot disc.
My2647 lost files cant download
http://www.google.com.ua/search?q=Polaroid%20PMIC%20702c&sugexp=chrome,mod%3D8&um=1&hl=ru&biw=1366&bih=643&ie=UTF-8&sa=N&tab=iw&ei=-iikUOXLM-ja4QS9_IHwCw#hl=ru&gs_nf=3&pq=polaroid%20pmic%20702c&cp=6&gs_id=s&xhr=t&q=undelete&pf=p&tbo=d&sclient=psy-ab&oq=undele&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=16ef26e1bd4fd843&bpcl=38626820&biw=1366&bih=643
Bios code please
http://www-307.ibm.com/pc/support/site.wss/BMOE-3VAM8Y.htmlPlease use the address above and select your required bios. Thanks.
IBM Thinkpad T21 will not boot, worked fine 30 minutes ago...
| | Installing this wireless adapter couldn't have fried the motherboard, right? ||I would not have thought so .. the software may have caused an issue --- as the PC boots tap F8 you should get a menu - choose "last known good configuration" ---- if that does not work, reboot and again tap F8 as it boots and this time choose safemode - then see if you can restore start>programs>accessories>system tools>system restore> choose a date to before the data you installed the wireless adapter software
Thinkpad won't load xp
Try setting up xp again. If you need the files as is, try repair from the xp cd while boot from the cd.
"Cannot Find Server or DNS Error"
You guys could try the following to bring back the browser service, if it's not a connection or dns issue:
1. in the cmd run "regsvr32 actxprxy.dll" and "regsvr32 shdocvw.dll"
2. reboot windows
If the above couldn't fix the issues, run the following extra commds:
regsvr32 mshtml.dll
regsvr32 urlmon.dll
regsvr32 msjava.dll
regsvr32 browseui.dll
regsvr32 oleaut32.dll
regsvr32 shell32.dll
and restart the system once again
Thinkpad T21 won't start on battery alone. Works OK with adapter
The power comes into the plug on the back of the computer. This connects it to metal traces inside the mainboard of the computer. These will be connected to voltage regulators which often output 5 volts, 12 volts, 3.3 volts, and the CPU voltage; they sometimes look like the image at right.
These will be connected to cylindrical capacitors distributed throughout the mainboard. Capacitors act like tiny, fast batteries, supplying extra power where needed to maintain a steady voltage during high demand.
Anywhere in your laptop, physical or electrical damage can cause a short circuit. A short circuit will consume all available power, causing your laptop to not turn on. If your power adapter LED comes on when you plug it into the wall, but then goes off when you plug in the laptop, you probably have a short circuit.
Ibm thinkpad prompt: operating system not found.
that message means that windows 2000 professional/98 is not installed which means you have a blank computer you need to put the disk that came with it in and install the OS or purchase one but i'll warn you now those disk are not cheap around a couple hundred bucks
Screen is black
If it's still under warranty, IBM should come out & fix it. Call them.
How large of a hard drive is supported on the ibm t21
The ThinkPad T21 is a laptop with a single drive bay.
You cannot setup this laptop with two hard drives in any RAID configuration.
You can add an external USB hard drive and copy/backup data to this hard drive.
OR
You can connect this laptop to a network and copy/backup data to another computer/server on the network.
IBM T21 usb issue
u have to install drivers for usb connections.
i guess u have 98 version of windows. if u have windows 98 operating system u have to have install drivers for every USB devices.
feel free to ask me questions regarding this answer
chirag
IBM T21 doesn't start
try to start it with the battery out by pluging it straight, the battery is dead and its causing problems
