this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
I found that with most you have to pull the oven out of it's housing to remove the screws and wireing. You then remove the cover from within the oven, pull out the element then rescrew from the rear. Hope this helps?
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
Check if the oven timer is on auto mode. If it is, turn it on to manual mode .
Remove the power cable from the outlet and wait for 20 minutes. As you plug your oven back in, the oven timer should reset as well .
Hold the timer buttons down at the same time to reset the timer .
Meter the thermostat out and see if it's open circuit .
Take the top off and inspect the selector switch and see if there are any signs of burning on the switch .
How to Repair ' Smeg duel fuel range cooker A1-7 Oven not working. (how-to-repair.com)
It sounds like you're experiencing an issue with your SMEG DS96MFA7 oven where a noise occurs after some time of operation and continues even after the oven is turned off. Since you've already replaced the cooling fan and the noise persists, there are a few possibilities to consider:
Heating Element: The heating element in your oven might be expanding and contracting as it heats up and cools down during operation. This can sometimes create noises, especially if the element has developed some internal damage.
Cooling Fan Motor: While you've replaced the cooling fan, it's possible that the noise is coming from a different part of the fan assembly or from the fan motor itself. The noise might be due to vibrations, a misaligned part, or a problem with the motor bearings.
Exhaust Fan or Circulation Fan: Some ovens have additional fans for exhaust or circulation purposes. If your oven has these fans, they might be causing the noise. Check if there are any additional fans present and inspect them for any issues.
Expansion and Contraction: As the oven heats up during use and then cools down after being turned off, various components inside the oven can expand and contract. This can sometimes result in creaking or popping noises. This could include metal components, panels, or other parts.
Loose or Vibrating Components: Check for any loose or vibrating components within the oven. Even a small loose panel or part can generate a significant amount of noise, especially as it vibrates against other surfaces.
Gas Ignition System: If your oven uses gas, the ignition system could be causing clicking or ticking noises as it ignites and heats up.
Electrical Components: Certain electrical components, such as relays or transformers, could also be causing the noise if they are malfunctioning or vibrating excessively.
Since diagnosing the exact source of the noise can be challenging, especially without being able to inspect the oven in person, I recommend the following steps:
Carefully Inspect: When the noise occurs, try to pinpoint its source by listening closely and observing the oven's components. This might give you a better idea of where the noise is coming from.
Contact Professional Help: If the noise persists and is affecting the functionality of the oven, it's advisable to contact a professional appliance repair technician. They have the expertise and tools to diagnose and fix the issue accurately.
