20 Most Recent
Sony Ericsson Unlock Code For At&t Xperia X10 Questions & Answers
Unlock codes for a Sony Ericsson ST18i Xperia Ray : in plain English
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Manual sony esperia mini
go here for manual
http://www-support-downloads.sonymobile.com/st15/userguide_AE_ST15_1252-0138.1.pdf
W595 circuit board digrams
Does it work with just the battery or just the power supply? May need a new battery as they do not last forever. It may also need a new powers supply. Test if it works for one but not the other as that is the key.
No power w595 sony ericson
Probably shorted the power supply, but may have only blown the fuse. If you have a manual find where that fuse is and replace it. If it is not the fuse, replace the power supply, and cord as it is not expensive and is worth a try. Unfortunately, you may have fried the mother board. Amazon sells one for less than 50 dollars and it is easy to replace if you follow the instructions. There is a chance you may fried the CPU which could be more expensive. The hard drive is not, but may have been damaged too. It's worth a try on all counts as Sony's are not cheap to reacquire and that accident is not covered by your warranty as something that happens under normal use.
Unblock youtube
Hahahahah You've been BLOCKED by You Tube? (Or your parents?)
No service no signal
Check whether your sim is placed properly in the slot. Try to reinsert the Sim. Still if you face the same problem then your phone might be locked to particular Network. To solve this problem you need to get your phone unlocked. You can unlock your Sony Ericsson phone using unlock code. You can get the unlock code for your phone from your Network service provider or Network service provider or any third party online vendors like
Unlock-Zone.com here you need to specify your country, current Network name, IMEI number of your phone. Then they deliver unlock code to you through mail with unlocking instructions. Using this you can unlock your phone from Network lock easily.
