20 Most Recent
HTC PG41200 EVO View 7in LCD 4G Tablet Questions & Answers
How to root nextbook nx007hd
- Google and download Cydia Impactor (First result on Google) Extract it (desktop, wherever you prefer)
- Enable USB Debugging on your Tablet (Settings > Developer Options > USB debugging)
- Plug up your Tablet via USB, do not turn usb storage on, let windows try (and most likely fail) at installing drivers.
- Launch Impactor and select USB Driver Scan from the top menu (under USB). Let it do it's thing, reboot your PC after.
- Verify your tablet/android device is showing up on the start-bar as being plugged up/in (bottom right area)(this may not be needed depending on your setup)
- Relaunch Impactor (if rebooted ) and hit the Start Button
- Let it do it's thing.
- You should be rooted now go install SuperUser!
How do I do a screenshot
Hi Wayne,
Try this:
1. Hold down the POWER button and then press the HOME button.
2. That's it! Seriously, it's that easy! You'll see a message appear on the screen that says "screenshot saved to Camera shots". You can then go to your Gallery app to see the screenshots that you have captured.
How to download whatsapp on HTC tablet
Hi Tracey,
You may want to check their official website where you'll find the link to the apk :
WhatsApp for Android
- Download it and pass it on your tablet using your usb cable
- Install with an explorer program (make sure third party softwares are allowed in settings)
Here you go !
Have a nice day !
My Android tablet was on the charger charging, and
u have 2 options 1 is to get the tablet reflashed or the most common problem is that u have overcharged the battery and it will need a new one this problem is very common in tablets as opposed to i pads as the tablets only get the bottom market parts where as the ipads get higher quality components
Reset password htc phone
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
- With the phone turned off, press and hold the VOLUME UP and DOWN buttons, and then briefly press the POWER button.
- Wait for the screen to show the instructions on how to do the factory reset, and then release the VOLUME UP and DOWN buttons.
- Follow the instructions onscreen to factory reset your phone.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
