20 Most Recent LG Electronics Unlocked Optimus G Slate V909 8.9" 4G Tablet PC, GSM, nVIDIA Tegra 2 T250 Dual-Core 1GHz Processor, 1GB RAM android 3.1 Questions & Answers
2answers
When I reset my lg vslate tablet now the touch screen doesnt work
Attach to power charger. Try hard shut down then try reboot all while connected. Then at that point you should see your keyboard again once o/s is back up.
3/18/2015 7:14:00 AM • LG Electronics... • Answered on Mar 18, 2015
Phone does not recognize sd card
Make sure that the SD card itself is not bad. If you know the card works, try to see if the device will let you reformat the card in the device, if it does not see the card at all you may have to reformat it in a computer - doing in the device is the preferred method though. If you do need to do it in a computer you will need to find out if the card should be in the FAT32 or NTFS format. NOTE WHEN YOU REFORMAT THE CARD EVERYTHING ON IT WILL BE WIPED AWAY - COPY EVERYTHING ON THE CARD YOU WISH TO SAVE TO YOUR COMPUTER AND THEN COPY IT BACK ONTO THE CARD AFTERWARDS. You can also try posting your question in a fan based forum such as this to get more detailed answers http://www.howardforums.com/forumdisplay.php/621-LG Have a magical Day K
7/27/2014 3:15:19 PM • LG Electronics... • Answered on Jul 27, 2014
Replaced digitizer now black screen only
If the LCD was working before replacement, the most likely suspect is a loose cable connection. It is also easy to crimp those tiny flat cables, or to break the locking mechanism so the cable can work its way loose. Sounds like you booted to a black screen after repair, so I would walk back through it and double check every connection, then look at all cables closely in bright light and with a magnifying glass, to be sure nothing sustained damage (twist, crimp, etc.). Remember to check the power cable to the LCD, as well. No power, no backlight, no video.
7/18/2014 8:38:14 PM • LG Electronics... • Answered on Jul 18, 2014
Google locked lg gpad x 8.0
Sadly, you need this information to use the phone. At the moment, there are some online resources that claim that they can bypass the Google lock however I've not used any such service and can't verify their claims.
12/26/2018 9:05:09 PM • LG Tablets &... • Answered on Dec 26, 2018
How can I bypass a Google account on a lg lk460 tablet
If it's telling you the tablet is locked and requesting Google credentials to continue, you can't bypass that. That's an anti-theft feature. You'll have to have the owner of the last Google account who logged into the tablet log into it to continue.
9/26/2018 10:27:55 PM • LG Tablets &... • Answered on Sep 26, 2018
To connect my fintie keyboard to my LG tablet
If that's a BT (bluetooth) kb, you need to go to the tablet Settings, Bluetooth, turn on BT, you might have to tap the More link/button, locate the kb, and add it to get it to pair.
4/29/2018 1:12:51 PM • LG Tablets &... • Answered on Apr 29, 2018
I have an lg tablet & my cellular network is with Consumer Cellular & as long as I'm on wifi it works. What do I need to do to be able to use my network away from wifi?
If it does not an ethernet connection you are out of luck. If you have an Iphone you can turn on hotspot.
4/22/2018 5:30:11 AM • LG Tablets &... • Answered on Apr 22, 2018
0answers
2answers
My Lg tablet fell and now the screen wont respond is there anyway to open to get my pictures and music
take it to a repair shop to determine the exact fault screens are replaeable but if it is a hard drive you are in trouble
3/18/2018 12:34:27 PM • LG Tablets &... • Answered on Mar 18, 2018
2answers
Want to clear out all my stuff to give my LG tablet away how do i do that
The model number LGV498, the LG G Pad II 8.0 design is similar to its predecessor. However, the tablet is seen featuring full-size USB port, which can be used to connect with portable drives, keyboards, and gaming controllers, apart from being used to charge other devices as well. This tablet comes with a slimmer capacitive stylus with 3.5mm width. Besides a support for an external storage via microSD card (up to 128GB), the LG G Pad II 8.0 houses the company's own LG-QPair 2.0 app, Microsoft Office apps and Quick Memo+ feature among others. The KnockON feature is also included. As for the specifications, the Android 5.0 Lollipop-based LG G Pad II 8.0 tablet equips an 8-inch WXGA (1280x800 pixels) resolution IPS display like the first-gen G Pad 8.0, and is powered by a 1.2GHz quad-core Qualcomm Snapdragon 400 processor, clubbed with 1.5GB RAM, which is a slight bump from the previous generation's 1GB. The LG G Pad II 8.0 includes an inbuilt 32GB of eMMC storage, along with Bluetooth 4.0, GPS and Wi-Fi connectivity options. Measuring 210.8x124.2x8.95mm, the tablet weighs 347 grams and is backed by the same 4200mAh battery for 10 hours+ of use. Hope this honest review help in your decision to this amazing LG tablet Amazon com LG Pad 8 0 16GB 2nd Gen GSM Unlocked by AT Wi Fi Android Tablet...
2/15/2018 2:43:45 PM • LG Tablets &... • Answered on Feb 15, 2018
LG Electronics Unlocked Optimus G Slate V909 8.9" 4G Tablet PC, GSM, nVIDIA Tegra 2 T250 Dual-Core 1GHz Processor, 1GB RAM android 3.1 Logo
8 questions posted
Top LG Tablets & eReaders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • LG Tablets & eReaders
Most Popular Question
when reset lg vslate tablet now touch
  • Tablets & eReaders
