20 Most Recent
Linhof 4x5 Master Technika 2000 Body - Black 000121 Medium Format Camera Questions & Answers
I need an instruction manual
go to www.hpmarketingcorp.com. Click on Linhof, go to the bottom of the page and click on Linhof Factory Site. Click on Service at the top of the page (make sure you selected English rather then German). Click on downloads and you can download the instruction book at N/C
Volume buttons dont work
There are no volume buttons on a Linhof camera and it is not a medium format camera. If you have a Linhof problem you can call us at 800 735-4373 or Linhof service at 252 652-4401 if you are in the USA.
Just installed windows xp and my speakers dont work
if your pc came with a motherboard cd then insert this cd an auto play will pop up run the cd from there and select all drivers everything will be installed hope this helps if it doesnt work then check the jack the speaker goes into the green jack.
Hi pls my tv screen is smashed and broken and i
FixYa is an online information resource only, it does not supply any spare parts.
But if you have a broken tv screen (you've listed your question in a section for Linhof Technika photographic cameras) then you have broken the single most expensive component in the tv. It's always cheaper to buy another complete tv, especially if you buy a used one.
I have a very old
Not sure if this will solve the problem but you could try here http://www.cameraspareparts.co.uk/
12/3/2017 6:15:59 PM •
Linhof...
Answered
on Dec 03, 2017
The lowest section of one
Linhof photographic equipment is sturdy and robust, designed for use by busy professionals. I cannot understand how you can break this item not once but twice. Take it to your local repair facility and get them to repair it for you.
5/5/2017 9:39:26 AM •
Linhof...
Answered
on May 05, 2017
Have older model "Expert" &
What is the head the telescope uses. Rarely do these line up and most solutions are going to end up requiring some creative engineering. I would say the easiest is to remove the old head, trace it out on a block, and then block trace the pattern on the other side from the telescope. This would give you a single shunt that both parts can join to.
6/25/2010 5:13:14 PM •
Linhof...
Answered
on Jun 25, 2010
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
