20 Most Recent Amazon Kindle Keyboard 3G, FREE 3G Wi-Fi, 6 inch E Ink Display - Grey Questions & Answers
Kindle 2 will not charge with empty battery message
just try another charging cable and if it did not work then go forbattery replacemant.....may be batt has died due to discharge
8/17/2017 10:09:35 AM • Amazon Kindle... • Answered on Aug 17, 2017
My battery is dead and wont recharge. The orange light comes on briefly then goes out completely.
You have a blown capacitor. You will need to open it up, find the capacitor (the top will be convex instead of flat) and replace it. It is delicate work, so only do it if you are familiar with this kind of work. Otherwise, find a friend who is good at repairing sensitive electronics.
11/27/2014 5:10:49 PM • Amazon Kindle... • Answered on Nov 27, 2014
Did not get my free kindle for signing up to prime
If I recall correctly, if you buy a kindle, you get free prime for a year. Not if you signup for prime, you get a free kindle.
10/12/2014 2:59:02 PM • Amazon Kindle... • Answered on Oct 12, 2014
When trying to read an ebook of Amazon on my PC I am told to update my software. How do I do that?
hi, to update the programme if you open the installed version you have on the settings you should have check for updates.this will update the programme you have to the latest version.if this is not avaliable you can search for mobi kindle books reader find the operating system you have and download and install that version good look hope this helps.
4/22/2014 1:41:54 PM • Amazon Kindle... • Answered on Apr 22, 2014
Charging port replacement
If you've tried other cords as well as tried holding down the power button for a minute and trying to restart your problem is most likely your micro usb port/pwr jack. It has separated from the board and needs to be re-soldered and made sturdy again. If you are great with a soldering iron you can do the repair after watching a few youtube videos but it is a tight and tiny repair. If not I strongly recommend sending it to us. We are fast, thorough, very familiar and make the port more sturdy than factory original. www.rockhoptec.com
3/20/2014 4:32:14 PM • Amazon Kindle... • Answered on Mar 20, 2014
Kindle keyboard won't charge
Have you tried another charger in case the charger is faulty? Have you tried resetting the Kindle? (Slide power switch and hold in place for 20 seconds).
3/19/2014 11:06:28 AM • Amazon Kindle... • Answered on Mar 19, 2014
5answers
Kindle fire screen is blank
Try doing a hard reset of your Kindle Fire as advised on the Kindle Fire Support web site for dealing with Screen problemsIf you still have a problem after doing the above, then you follow the additional steps advised on the above web page, i.e. ensure the Kindle Fire is fully charged (the power indicator has changed from Orange to Green) and that you have the latest Software Updates installed (assuming you can view the screen to do so!).
6/12/2018 7:32:17 PM • Amazon Kindle... • Answered on Jun 12, 2018
2answers
Instructions for the kindle
See the Kindle Support web page and then select your particular Kindle device after which you can follow the instructions for that device which are shown on the web page.See the Kindle Documentation web page for further manuals
3/17/2018 4:34:01 PM • Amazon Kindle... • Answered on Mar 17, 2018
How long should a Kinlde d00901 battery last as in years?
just get a new one
6/8/2017 10:05:21 PM • Amazon Kindle... • Answered on Jun 08, 2017
Kindle fire screen is green
I was having this exact same problem. I did a little research but to no avail, until I found this site. Just as I went to test some of these suggestions out, I found the screen had just returned back to normal as if nothing was wrong. Maybe give it a little time to work? I've been using it during its screen problems and it seems perfectly fine (aside from the green tint). Now my kindle is as good as new, so maybe you just have to wait a bit.
11/6/2015 2:16:41 AM • Amazon Kindle... • Answered on Nov 06, 2015
2answers
My Kindle Fire will not start
If you last charged it with the computer USB port, try charging with the supplied AC adapter instead. If you last charged with the computer USB port, try charging with the AC adapter this time. This will help isolate a bad AC adapter / power cord or USB cable / USB port.It is important to note that if you are charging your Kindle via USB port on a computer, when many computer enters "sleep mode" the USB power is shut off at this time too. Charging is effectively halted - even though still connected. You should only expect to charge while the computer is active or when using the AC adapter. You can also purchase an aftermarket DC charger. These are small plugs that are inserted into your auto's port or cigar lighter. They provide 1 or 2 USB connectors to plug in a USB cable. These devices are suitable to supply / charge just about any devices that uses a computer's USB port to power / charge a device. They cost anywhere from $5 and up and look something like this:5_22_2012_12_50_36_pm.jpgI hope this helps and good luck!
7/17/2013 6:48:46 PM • Amazon Kindle... • Answered on Jul 17, 2013
Need maqnual for kindle
Here you go! Download the manual you need from there.
8/31/2012 5:09:24 PM • Amazon Kindle... • Answered on Aug 31, 2012
Unfreeze my Kindle Fire
Take the Battery out and the sim card leave for a couple of seconds and put them Back in and turn your phone on, it should work
7/2/2012 11:22:57 PM • Amazon Kindle... • Answered on Jul 02, 2012
Where can I get instructions on how to use my kindle
You should be able to find what you are looking for at the kindle support page on amazon.com
2/27/2012 9:51:19 PM • Amazon Kindle... • Answered on Feb 27, 2012
Kindle
You can find the instructions on Amazon's website, www.amazon.com .
1/9/2012 11:30:40 PM • Amazon Kindle... • Answered on Jan 09, 2012
2answers
Kindle set up
See the Kindle Support web page and then select your particular Kindle device after which you can follow the instructions for that device which are shown on the web page. See the Kindle Documentation web page for further manuals
1/9/2012 11:01:31 PM • Amazon Kindle... • Answered on Jan 09, 2012
Delete unwanted items on a kindle
On my Kindle you go to the Home screen, press the left arrow on the 5 way controller, and select Remove from Device.More information here, by selecting your Kindle model and then selecting from the choices which follow - Organizing Content - Removing Contenthttp://www.amazon.com/gp/help/customer/display.html/ref=kinw_myk_lnav_help?ie=UTF8&nodeId=200127470
1/5/2012 10:07:00 AM • Amazon Kindle... • Answered on Jan 05, 2012
My WiFi keeps going off even when I turn it on
I assume that you mean the WiFi connection on your Kindle keeps going off and that you have checked that other devices connecting to the same WiFi router / access point are not experiencing the same problem, only the Kindle?If it is only your Kindle having this problem, then it may be worth checking that you have the latest version of software on the Kindle which you can do by visiting the Kindle Support web link in this update - select your correct Kindle device then follow the steps to check that you have the most up to date software installed.The Kindle Keyboard should update itself automatically but can also be done manually if necessary.If that doesn't work, then you may need to Reset the Kindle by pressing the Power button for 20 seconds - this will do a re-boot of the Kindle OS which may cure the problem is it is caused by some temporary problem.Have you checked what your battery status is when the WiFi goes off - this may happen when the battery levels get very low - the WiFi will add extra drain on the battery and cause the battery life to be reduced if left on full time.
1/3/2012 4:55:03 PM • Amazon Kindle... • Answered on Jan 03, 2012
2answers
How to Download Alexa app for Echo device?
Also you can check out ifttt site for thousands of work around. Goof Luck. https://www.the-ambient.com/guides/amazon-alexa-missing-manual-130 Set Up Your Echo
4/17/2024 10:33:07 AM • Amazon Computers... • Answered on Apr 17, 2024
Amazon Kindle Keyboard 3G, FREE 3G Wi-Fi, 6 inch E Ink Display - Grey Logo
24 questions posted
Top Amazon Computers & Internet Experts
vince
Paul Carew
Are you an Amazon Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Kindle Amazon
  • Kindle Amazon
Most Popular Question
kindle 2 will not charge empty battery
  • Computers & Internet
