20 Most Recent
Smeg SUK91MFX5 Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Falling shelf
Hi, Did you find a solution to this problem? As i have the same thing happening to mine.
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit
www.GasSafeRegister.co.uk
or ring freephone 0800 408 5500
Fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
My smeg oven,(bottom fan oven)
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
My Smeg gas oven lights up when I press the knob to light but as soon as I release the knob the flame dies?
Question edited for clarity.
The thermocouple safely device needs replacing. It's job is to make sure there is a good pilot flame before opening the main burner valve. When they fail, the flame goes out. You can try holding the knob longer, or just call for service and have it replaced. It is a gas appliance so should only be worked on by a gas certified technician. It is a fast job, in and out in 30 minutes, so call out plus the part.
OK for smeg gas stove circuit wiring diagram mode3 C9GGSSA-1
As an AI language model, I do not have access to specific product information or wiring diagrams. It is important to obtain the correct wiring diagram for your specific model of gas stove to ensure proper and safe installation. I recommend consulting the user manual or contacting the manufacturer or a licensed electrician for assistance.
