20 Most Recent Lexar Media Echo ZX 32 GB Flash Drive Questions & Answers
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Lexar Media Echo... | Answered on Sep 23, 2012
Flash drives give notices like that when the files or system on them is corrupted. Put it in again, and select "fix problem" if that option shows up. If not, go to file explorer, find it and right click on it and click "format". (you will lose any files on it, but by this time probably anything on it will be useless anyhow.) If none of these work, you may need to buy a new one.
Lexar Computers... | Answered on Jan 03, 2018
They are not designed to be user serviced so they only way to open them would be to pry the case apart making sure to avoid putting pressure on the circuit board connected to the USB plug.
Lexar Computers... | Answered on Sep 11, 2014
Try putting hard drive into another computer as a slave then format it ,that should cure it dont forget to change the little switch thingy from master to slave though
Lexar Computers... | Answered on Apr 26, 2014
Usually this is and issue with the usb host to pci bus driver check the support website for a new one. PS usb 2.0 function usually doesn't just stop working on the flash drive itself
Lexar Computers... | Answered on Sep 28, 2010
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
Lexar Computers... | Answered on Sep 09, 2010
the disk is write protected
Lexar Computers... | Answered on Aug 28, 2009
https://www.google.com gives several obituaries with that name.
Of course, condolences if this is a personal contact.
Example:
https://www.mourningglory.ca/notices/Lois-Benneke
Computers &... | Answered 54 minutes ago
Hi Use the following code
#7465625*746*Code# ( Disables SIM lock)*7465625*746*Code# ( Enables SIM lock)
Use this code on your phone to disable/enable SIM Lock on E250
Computers &... | Answered 3 hours ago
buy a new one
Computers &... | Answered 6 hours ago
Generally, thesis would be always a lendy in everyway. Certainly, It would be consist of many component parts that you can't missed it in your thesis writing. If you are really searching for some one to help you writing in a thesis in the tourism or any specific topic then get helped here with powered essay. But the question is have you ever heard about the powered essay. Worry not, read yourself about the powered essay and their service. www.poweredessays.com/writing-thesis-statement
Computers &... | Answered 7 hours ago
First of all download the link below:
https://ninite.com/revo
then run it and uninstall the trend micro installation and any other programs like old expired anti-virus, that you don't want.
afterwards if you want an Anti-Virus on your machine you might try Avast. You can get it at the link below INSTALLED for you for free. The Avast has two versions Free and Paid. when it is installed it is free. If you want to upgrade then purchase the paid one. But I will tell you right now I cannot remember the last time that I had paid for a Anti-Virus.
Once you have Avast installed make sure you run a FULL SCAN of the HARD DRIVE. Good Luck.
https://ninite.com/avast
Computers &... | Answered 8 hours ago
post model o f sound system. name and model and TV model.
we cant see what you own only telling makes help possible
Computers &... | Answered 10 hours ago
Lexar Media Echo ZX 32 GB Flash Drive Logo
2 questions posted
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
CarlosIjalba
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexar Computers & Internet
Most Popular Question
wiring diagram usb flashdrive
  • Computers & Internet
