20 Most Recent
IBM eServer xSeries x226 Questions & Answers
I have IBM X226 Server
try to see if the processor is overheating, try to clean it and put a bit of thermal paste
How do I set it up as a computer
Format the drive that has the operating system on it. None of the programs on it will work once it has windows 7 or 8 on it. Server software IS different even though it may have the same name. Now, the tough part. Before you format, get the motherboard model number off it. It's sill screened somewhere on the board. Next go the the BOARD manufacturer's web site to get the drivers needed for windows. Next , do the same for all the devices you have connected such as CD rom drives, mouse, keyboard , modem, network card, video card, These drivers are needed to replace the server drivers with PC drivers. After you have gathered up all the new drivers, format the hard drive and install windows. You'll soon find out which drivers are necessary. Install them as needed. You will have to buy PC versions of the software programs you need and then install them as well. That should get you going.
I get 3-3-3 beeps no display
Check ram , remove ram and clean it and ram slot also , then fix ram on ram slot then start , if does not start then use another ram , then after all its does not start then check you mother board
if it is helpful then vote yes
Micromax speaker repair
You can open up the side cover to ensure that if the speaker jack is porperly plugged in or not because it sometime happen because of taking anything apart.
Error three short beeps and three times
Hello,Most of the time this is a memory error code. Have you added new memory cards? Sometime the cards are not seated well, are the incorrect placement (cards need to be in pairs) Check that and post your results. Good Luck.C2Solutions
I get physical memory dump error while installing
Hello, This is a hardware compatibility issue. (Most times) when installing server 2003 and it keeps dumping memory. Check to make sure your system is the correct configuration for the Windows Server 2003. Good Luck .C2Solutions
Only 3-3-3 beepcode when my
either your moitor went out ? or your video card? try hooking it up to a monitor that you know that works, if it boots up you need a monitor ! if it doesn't then you need a video card ! hope this helps !
2-2-1 beepcode IBM X226
Beep codes vary with different manufacturers. The following link will tell you more about the meaning(of 2-2-1):
http://www.computerhope.com/beep.htm
I get 3 beeps in x226 server
Short the BIOS or remove the internal battery and replace after a couple of min and set everything in BIOS settings to default............sodeep
Raid configuration
When your system boots up you should see an option to access your raid controller if not or if your system doesn't see the controller at all you will have to download the utility software from IBM, but you need to be careful any change you make in the configuration of the disks will delete all data on your drives. This is non-recoverable loss. The utility has help and is fairly easy to understand.
