20 Most Recent
Pelican Duo Force 2 Dual Analog Force Feedback Controller PSX Questions & Answers
How to turn off pelican sabrelite 2000
To turn off the Pelican Sabrelite 2000 flashlight, you will need to locate the switch or button on the flashlight that controls the power.
On most models of the Pelican Sabrelite 2000, the power switch is located on the tail cap of the flashlight, near the base. To turn off the flashlight, you will need to press and hold the power switch for a few seconds until the light turns off.
If you are unable to locate the power switch or if the flashlight is not turning off as expected, you may need to refer to the owner's manual for your specific model of Pelican Sabrelite 2000. The manual should provide information on the location and operation of the power switch and any other controls on the flashlight.
If you are unable to find the owner's manual or if you are still having trouble turning off the flashlight, you may need to seek further assistance from the manufacturer or a technical support professional. They will be able to provide you with more information on how to operate your specific model of Pelican Sabrelite 2000.
My pelican adapter from ps2 to ps3 via usb will
could be that the adapter is a 3rd party adapter and that would be it doesn't pass the qualtiy that Sony requires before it puts its stamp of approval on the item which means your taking a chance on the item working.
See if you can find an item that is approved by sony and then try that.
