20 Most Recent Smeg FAB28 Questions & Answers
A very difficult to open fridge door
is it level do you wait for the cold air to balance inside the fridge after opening it and closing it often try vasaline on the seal edges if the handle or hinges are the problem will require replacement parts or adjustment 26282238-1px5ajpdykg4ojfw3qrotemj-1-0.jpg
9/14/2016 9:24:27 PM • Smeg FAB28 • Answered on Sep 14, 2016
4answers
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
7/9/2015 1:32:37 PM • Smeg FAB28 • Answered on Jul 09, 2015
2answers
How do i stop a large block of ice forming outside the fridge on the pipe behind the fridge ,left hand corner on floor I have a Smeg fab28p6
Wrap the pipe with foam insulation, bought from a DIY/Plumbing shop!
11/3/2014 12:25:18 AM • Smeg FAB28 • Answered on Nov 03, 2014
0answers
No power
Be the first to answer 4/8/2014 4:46:02 AM • Smeg FAB28 • Posted on Apr 08, 2014Be the first to answer
0answers
Clicking noise
Be the first to answer 3/12/2014 9:55:27 PM • Smeg FAB28 • Posted on Mar 12, 2014Be the first to answer
0answers
Fridge not getting cold
There are 3 likely possibilties, either the compressor is heating up and tripping or if the compressor is working there is a leakage of gas, the third is there is slight moisture or jamming in coil, filter or pipes which is causing uneven cooling. Cheerio
11/10/2013 12:19:46 PM • Smeg FAB28 • Answered on Nov 10, 2013
manual
FAB28 Manual
Smeg RefrigeratorsUploaded on Aug 26, 2013
0answers
Change light bulb
Be the first to answer 4/27/2013 2:57:22 PM • Smeg FAB28 • Posted on Apr 27, 2013Be the first to answer
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
12/11/2012 12:09:06 AM • Smeg FAB28 • Answered on Dec 11, 2012
0answers
0answers
0answers
0answers
Not Cooling ??
Be the first to answer 8/13/2012 6:43:53 PM • Smeg FAB28 • Posted on Aug 13, 2012Be the first to answer
My icebox seems to cause
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/19/2011 2:53:10 AM • Smeg FAB28 • Answered on Sep 19, 2011
My icemaker seem to cause
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/19/2011 2:52:09 AM • Smeg FAB28 • Answered on Sep 19, 2011
Water leaks from bottom corner hinge side of door
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/10/2011 6:08:36 PM • Smeg FAB28 • Answered on Sep 10, 2011
Smeg FAB28 Logo
49 questions posted
Top Smeg Refrigerators Experts
Jay Finke
Jay Finke
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Smeg Refrigerators
  • Smeg Refrigerators
Most Popular Question
took wiring apart
  • Refrigerators
