20 Most Recent
Smeg FC40RX Bottom Freezer Refrigerator Questions & Answers
Hi, we just defrost our
some of these new fridges have a delay timer and can take up to 10 minutes to reset. check to see you have power at the plug.. use a hair drier low heat .. make sure the stat is set.. duh .. hey it happens to the best of us .. jay
Freezer just stopped working
Several problems can cause this. It may be "stuck" in the defrost cycle, the compressor start device could have failed, the temp control system could have failed, evap fan could be bad and not circulating cold air, or worst case is the sealed system has leaked all the refrigerant out. Post again with more info like:
Is the compressor running?
Are there any fans running?
Does the temp control turn the compressor off and on?
It never hurts to unplug the unit for a few minutes and then plug it back in to see if it will kick over and run again. We'll have to go back and forth with some troubleshooting to narrow it down.
Prevent SMEG fridge from dripping on floor
please make sure that food isn't being pushed against the evaporation plate
Also, please make sure that the outlet pipe isn't blocked with food debris.
Thank you.
10/28/2022 2:09:13 AM •
Smeg...
Answered
on Oct 28, 2022
