20 Most Recent
Smeg FA561X Side by Side Refrigerator Questions & Answers
We had a power cut
I had that happen before to a older fridge ,power surged my heating element .
Smeg FA561X ice maker not
ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- In most of the cases the fault is water valve at the back of ice maker section, on some refrigerators the valve is at the lower section. ------------- The above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
SMEG Fridge Freezer FA561XF - the frame of the fridge/freezer gets very hot and freezer isn't freezing stuff in bottom tray
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink. Also, if the machine is too close to the wall or the condensor coils are dirty you'll get the same effect, so be sure to check those things out as well If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
