20 Most Recent
Jensen SCR-60 Stereo Cassette Player with AM/FM Radio and Bass Boost Boombox Questions & Answers
Jensen cr220x wiring
contact me at
[email protected] I have the same stereo and I have it wired... with the stock connector..
I'll chase the pins down for ya... just contact me.
this 60 watt deck is AMAZING..
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
