20 Most Recent
IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop Questions & Answers
When i press power on
Overheating. The shutting down is a fail-safe. You need to first open your cabinet and check your fans and make sure that your computer aren't filled with dust. If it is blow it out with air duster and it should solve the problem.
If your fans have failed, you'll need to replace them. If they haven't, your next step is to increase their speed. The utility below will monitor you temperature and increase your fan's speeds to keep the system cool. If you are unable to cool your computer down to the point where it stays on, your power supply had gone bad and needs to be replaced.
http://www.almico.com/speedfan.php
I cannot skype or play music, when i try to skype
Hello Naudia.
it seems like a problem with the soundcard-driver. maybe there is non or the wrong driver installed. check in the device-manger and try to reinstall the driver os deinstall and install new.
i hope this fix youre problem.
lg. Gue.
When i installed xp on
The drivers are available from Lenovo incl a BIOS update for the model ThinkCentre M50 8189-F6G:
support.lenovo.com/en_US/research/hints-or-tips/detail.page?&LegacyDocID=MIGR-50534
