20 Most Recent
Icon Kindle Fire/7 inch Tablet Case - Plaid Questions & Answers
How to reset a kindle fire
Press and hold the power button for fifteen seconds or so, ignoring the "Shut down" prompt until it turns off. Release the button, then press and hold it for a second or two until it starts to reboot.
Deregister
You can do it under your Amazon account, or use the Fire, if it is connected to the network.To do it with the Fire, press the Quick Settings Icon (the spoke in the upper right hand corner), then press More. Then select My Account: Displays the Amazon account name to which your Kindle Fire is registered. There is also a button for registering/deregistering your device.
I want to put talktalk icon on desktop pleasr
Go to the site you want the shortcut to, Copy the address in the address bar, right-click the Desktop, click New, Shortcut. Paste the address into the pane that comes up, click Next, give the shortcut a helpful name.
All icons on Windows 10 desktop changed to Firefox icons
It sounds like the default program for opening files and folders on your Windows 10 desktop has been set to Firefox. To resolve this issue, you can try the following steps:
- Right-click on a folder or file on your desktop and select "Properties" from the context menu.
- In the "Properties" window, click on the "Change" button next to "Opens with".
- Select the program that you want to use to open the folder or file, such as File Explorer, and click "OK".
- Repeat this process for each file type that is opening in Firefox.
If this doesn't resolve the issue, you can try resetting the default programs for all file types by following these steps:
- Press the Windows key + I to open the Settings app.
- Click on "Apps" and then select "Default apps" from the left-hand side menu.
- Scroll down and click on "Set defaults by app".
- Select the program that you want to use as the default for each file type, such as File Explorer, and click "Set this program as default".
Once you have reset the default programs for all file types, the icons on your desktop should return to their original appearance and open in the correct program.
Tripp-lite omni900lcd, continuous beeping.
if your model has a mute/test button, please press this for 3 or 4 seconds to stop the beep. The beep usually indicates an approaching power shutdown of the device and allows you to save any files that are currently in use prior to this shutdown.
Thank you.
Making a desk top icon
Your desktop icons may be hidden. To view them, right-click the desktop, select View, and then select Show desktop icons. To add icons to your desktop such as This PC, Recycle Bin and more:
- Select the Start button, and then select Settings > Personalization > Themes.
- Under Themes > Related Settings, select Desktop icon settings.
- Choose the icons you would like to have on your desktop, then select Apply & OK.
I want to make a new icon
Ad camara icon to desk top
Want to put personnel Gmail in an icon on desktop
- Choose the icons you would like to have on your desktop, then select Apply and OK.
