20 Most Recent
Audio Technica Audio-Technica ATM25 Microphone Questions & Answers
I am getting a high pitch poping sound from my
If this is only when you hit the bass drum, it's picking up feedback from being too far inside the drum or pointed at the wrong part of the head. Use a mic stand and position the mic off to the side, but in front of the head, pointed at the midway point between the center and edge of the drum head. This should eliminate the problem. If the noise is still present, have someone qualified to work on microphones look at it to determine what the problem is.
Hope that helps! Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/cameron_463100ffd54b591d
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts.
You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
