20 Most Recent HTC Sensation XE Z715E Beats Audio Smartphone Unlocked Questions & Answers
Bluetooth not working
follow this steps and fix it. God bless you Check your connection. If your Bluetooth will not connect to your phone, it's possible that it isn't paired or has lost its pairing with your phone. Begin by powering off your Bluetooth by pressing the multifunction button located at the top of the device.
    • 2
On the Nokia 6555 press the center "Select" key, located in the middle of the circular navigation keypad. This takes you to the phone's main menu.
    • 3
Use the navigation key to scroll to "Settings" and press the center "Select" key.
    • 4
Scroll to "Connectivity" and press the center "Select" key.
    • 5
Scroll to "Bluetooth" and press the "Center select" key.
    • 6
Scroll to "On" and press the center "Select" key.
    • 7
On the main Bluetooth menu, scroll to "Search audio enhancements" and press the center "Select" key.
    • 8
The phone will automatically search for available Bluetooth devices. When you seen an icon that says "Philips SHB 1300," press the center "Select." Your phone will be paired or reconnected to your Bluetooth. 2. Dead Battery o 9 Another common and easy-to-solve Bluetooth problem is the headset's inability to turn on. A dead battery is the likely culprit here. o 10 Plug your Bluetooth into the power cable that came with it. o 11 Plug the power cable into a wall outlet. o 12 Allow your Bluetooth to charge for three hours. o 13 Recharging the battery will give you about seven hours of talk time or up to 200 hours of standby time before you'll have to charge it again
10/29/2013 11:39:27 AM • HTC Sensation XE... • Answered on Oct 29, 2013
The headset mode is on,
I reckon yer phone is stuffed as there is a loose connection in the headset jack and thus the phone thinks there is a plug in there all the time. The only suggestion l can make is to get nail 3.5mm the size of the plug and stick it down the hole an give it a wiggle (at yer own risk of course ) this should shake up the connections an should be all good again.
12/4/2017 7:35:40 AM • HTC Radio... • Answered on Dec 04, 2017
0answers
HTC Stereo Headphones is better than sony ?
Yes. HTC headphones are better than Sony nowadays.
12/31/2014 6:31:27 AM • HTC Radio... • Answered on Dec 31, 2014
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM • Radio... • Answered on Apr 19, 2024
2answers
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM • Radio... • Answered on Apr 04, 2024
The LED light display is not working on the face of detachable headset is there some button i can press to enable Firetail FT-8238D
I have the same problem. When o remove the interface the led is not flashing as per the instruction manual
3/27/2024 5:24:11 AM • Radio... • Answered on Mar 27, 2024
I need a manual for a TRONIC PLL 2023 radio. Can you help? Ray
http://www.manuals.group/results.php?search=TRONIC%20PLL%202023%20KURZ
3/26/2024 7:06:10 AM • Radio... • Answered on Mar 26, 2024
I have a Sonoff switch device which worked fine until I changed Broadband. Now the eWeLink cannot pair to the device??
Home - SONOFF OfficialSONOFF Official https://sonoff.tech Explore the innovative world of SONOFF, learn and chose about various smart home products, define your smart home,your smart choice!‎SONOFF Products · ‎Basicr2 · ‎ZigBee Bridge · ‎Home AUTOMATIONA Thorough Pairing Guide To SONOFF Smart Devices And ...SONOFF Official https://sonoff.tech > product-review > tutorial > how-to-p... How to quickly pair sonoff smart devices with ewelink app? This guide covers a complete and instuitive pairing instruction for all sonoff devices.Contact maker support. It is likely an issue with the new broadband router. The will know if there are compatibility issues..
3/24/2024 6:49:12 PM • Radio... • Answered on Mar 24, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please. Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity. https://www.google.com/search?q=KPG-790 ..
2/15/2024 3:06:45 AM • Radio... • Answered on Feb 15, 2024
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero. https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive https://www.google.com/search?q=KEM+P29923 ..
2/9/2024 1:12:05 AM • Radio... • Answered on Feb 09, 2024
New Motorola Mag One radio fully charged will transmit but will not receive. why?
This question edited for clarity. Contents of correction Question added here and Deleted. Did you read the Manual? It looks like it has Volume Buttons on the side and may be set to Zero volume? https://www.motorolasolutions.com/en_us/support.html https://www.motorolasolutions.com/en_us/products/two-way-radios/analog-business-radios/portable-radios/bpr40.html#tabproductinfo ..
1/18/2024 7:03:58 PM • Radio... • Answered on Jan 18, 2024
Pin for tzumi earpiece Bluetooth
i need a code for my ear piece
12/29/2023 7:49:36 AM • Radio... • Answered on Dec 29, 2023
HTC Sensation XE Z715E Beats Audio Smartphone Unlocked Logo
1 questions posted
Top HTC Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a HTC Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • HTC Radio Communications
Most Popular Question
bluetooth not working
  • Radio Communications
