20 Most Recent
Panasonic Lumix DMC-FZ3 Digital Camera Questions & Answers
Fixing the dead ON/OFF switch of a Panasonic Lumix DMC FZ3
Most firms, Panasonic included, only will sell Service Manuals to certified repair centres. So a chance you find one on the net is virtually zero.
The only chance I can think of, is looking on ifixit.com. They will publish manuals and videos of electronic equipment, they ever did get in their hands. They also can help with tools and spare parts.
I downloaded some pictures as well as a video
Does the program give you any option to see where the video is stored on your hard drive or any option to export? As the video's are now on your computer but it's a question of where, as well are you using a mac or windows?
M having Panasonic Lumix DMC-FH3
Sounds like the card is from another camera or was formatted on a computer. If there are pics on it you want to save, download them using a card reader if necessary. Then, format the card in your camera.
I have a question about a Panasonic
Did the "great" instructions from instructables happen to mention the need for specialized alignment equipment when re-assembling the lens?
DPI
Have you looked at the number of inches that 72 dpi is spread out over? 72 dpi is the standard default setting for any digital camera. What matters is the size that you actually print it at.
Notes on the camera
This type of thing has been reported for several different cameras. And it is considered normal.
Some models actually rattle when you shake the camera a bit.
Software for Lumix® Digital
No. These cameras store images in a JPEG format and can be used with any software package that can open a JPEG image.
My camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Where does my Lumix® digital camera storage path
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
DPOF Print Mark Function
The DPOF Print Mark Function allows you to sort through the SD Memory Card and select the images you want to print by electronically marking them. You can then print the marked images on any DPOF compatible printer by hitting the AUTO PRINT button.
Unlimited consecutive shooting function
This functionality allows unlimited consecutive shooting up to the capacity of the SD Memory Card in the camera—ideal for capturing fast-moving objects in high resolution. The number of shots may vary depending on memory card size, picture size, and compression.
Effective megapixels
Effective megapixels are slightly less than the total number of pixels normally stated for an image sensor. They represent the actual number of pixels used to record an image.
MEGA Optical Image Stabilizer
The MEGA Optical Image Stabilizer helps correct hand movement from shaky hands, one of the main reasons why cameras produce blurry images. Lumix® Digital Cameras with MEGA Optical Image Stabilizer technology have a built-in gyrosensor that detects any hand movement and relays a signal to a tiny microcomputer inside the camera, which instantly calculates the compensation needed. A linear motor then shifts the Optical Image Stabilizer lens as necessary to guide incoming light from the image straight to the CCD. You won't even notice it working—all you'll see are the outstanding results!
