20 Most Recent Panasonic Lumix DMC-FZ5 Digital Camera Questions & Answers
Cuando la enciendo en la pantalla dice(Modo dial en posicion in)
Los hp´s de Panasonic conocen la respuesta, pero por 100.00 porquer?a de c?mara!
3/9/2019 10:29:40 PM • Panasonic Lumix... • Answered on Mar 09, 2019
Error message remove lense cap
The lens is jammed in, either the unit has had a knock or there is debris (sand/grit) in the unit, been to the beach lately.
Check to see if the lens is sitting level with the front of the camera. Unit will probably need to go in for servicing.
8/15/2016 8:28:52 AM • Panasonic Lumix... • Answered on Aug 15, 2016
2answers
Why can't I download my photos? I have had no problem in the past. I had a virus which was removed, and since then a few things have not worked. Its windows XP
If you can view the photos on your camera, and they are stored on a removable device (such as a Sandisk), then you should be able to load the removable device into a computer and copy the photos using Explorer. If this does not work with Windows XP, it could be due to the fact that Windows XP is no longer supported with upgrades. I would try to upload the photos to a computer running a current version of Windows (scan the removable device for malware before uploading to the computer). If that works, it's time to upgrade your computer. (I upgraded my XP computer to a Linux OS.)
3/23/2015 1:37:23 PM • Panasonic Lumix... • Answered on Mar 23, 2015
I cant get my camera to turn on. Have charged and swapped out 4 different batteries and still wont turn on.
When you put your battery on the charger the light should come on to indicate charging, then go off when the battery is charged. Have you seen that?
12/19/2014 3:04:47 AM • Panasonic Lumix... • Answered on Dec 19, 2014
What size sd card for a lumix dmc fz5?
The DMC-FZ5 works with any SD card, 2GB or smaller. It will not work with higher-capacity SDHC cards.
8/23/2014 2:48:27 AM • Panasonic Lumix... • Answered on Aug 23, 2014
0answers
Drivers
Be the first to answer 4/18/2014 3:07:33 AM • Panasonic Lumix... • Posted on Apr 18, 2014Be the first to answer
0answers
Down load mac
first install the software that came with the camera on CD, to the computer. Only then you can connect the camera and manage the pictures on your camera and put them on your computer.
1/25/2014 2:58:20 PM • Panasonic Lumix... • Answered on Jan 25, 2014
0answers
0answers
0answers
Panasonic Lumix DMC-FZ5 Digital Camera Logo
169 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
format card in lumix panasonic camera
  • Cameras
