20 Most Recent
Rosewill RTK-T05 Network Cable Tester Questions & Answers
Hello
You could change your screen resolution on your computer......thats about all you can do.
7/25/2022 9:31:11 AM •
Rosewill...
Answered
on Jul 25, 2022
Laptop suddenly will not recognize my external hard drive
One thing to try is hooking it up to another computer. There is a possibility that the hard drive failed or the controller for the external storage device has failed. If it is recognized on another computer then I would look at the manufacturer's website for an updated driver
12/5/2017 2:09:41 PM •
Rosewill...
Answered
on Dec 05, 2017
Can i use my Rosewill LCD MONITOR as a tv
No. The monitor has no tuner in it and the scan frequencies used in TV's are different in monitors. Tuner modules will work on laptops and PC's with usb ports.
7/10/2016 10:12:40 PM •
Rosewill...
Answered
on Jul 10, 2016
Can i use a rosewill lcd monitor as a tv
That depends upon what you are using with it. Monitors do not have integrated tuners and thus cannot select channels. However, most cable providers use set-top boxes that perform the channel selection function for you. Many of these boxes have HDMI outputs that can be used with monitors that have these input capabilities. Otherwise, you need separate audio and video connectivity from the cable box to the set, either in the form of composite video plus audio cables, or a DVI cable with audio cables. Again, this is dependent upon what the cable box and monitor support.
7/10/2016 7:58:44 AM •
Rosewill...
Answered
on Jul 10, 2016
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
