20 Most Recent
Mad Catz MADCATZ MCB886060002/08/4 PLAYSTATIONR3 BLUETOOTHR HEADSET WITH BOOM MICROPHONE Questions & Answers
My mad catz head set
Sounds like you may have a defective unit. If it is under a year old I would contact the manufacturer immediately for a warranty replacement. Or you can start by taking it back to the store you bought it from if they offer any tech support. Hope this helps. Have a great day.
Cant hear anything
ya im having the same problem with mine, and im trying to play cod6. but i think its supposed to do that. but then again, why would they give u a earpeice if u cant hear anything. well, u can try pressing the volume up on the head set, and also go to accessory settings on your ps3 and turn it up. but im not sure if thats your problem, i havent tryed that yet. but hope it helps.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
