20 Most Recent Sony Cyber-Shot DSC-P200 Digital Camera Questions & Answers
Repair damaged n corrupted photos
If they are corrupted on the card, you are out of luck. The camera may not have saved them properly. See if you can review them through the camera. If they appear in the camera, use the USB cable to connect the camera to the PC and copy them that way. If they do not show up in the camera there is nothing you can do at that point.
1/10/2018 6:22:56 PM • Sony Cyber-Shot... • Answered on Jan 10, 2018
Something sticky spilled on my
you will need to flush the the area that is preventing the lends from opening ( I am guessing some sticky stuff is still in there )but without harming the camera some pure alcohol might do the trick but you dont need to flood your camera , maybe place it lens down and brush some alcohol around the area hoping it will dilute the stuff and run out of the camera and not run into the internal works. a hair dryer close at hand can evaporate up any residue alcohol that has gone astray .
9/26/2017 12:15:44 PM • Sony Cyber-Shot... • Answered on Sep 26, 2017
Pictures are too dark or too bright with Sony DSC-P200 Camera
U have an electronics issue with the circuitry controlling the light levels reaching inside. Have you tried using manual settings? Repair on those units is expensive and it may bot be a cost effective repair situation.
3/22/2017 1:20:15 AM • Sony Cyber-Shot... • Answered on Mar 22, 2017
2answers
Sony cybershot dsc p200 user manual
Press Menu and go to setup, set date and time option to adjust it.
You can download user manual of DSC-P200 by clicking Sony Support. for further guidance.
1/4/2015 9:26:01 AM • Sony Cyber-Shot... • Answered on Jan 04, 2015
2answers
Flash works but timing is off
If your camera is set properly there seems to be bad connection between shutter and the flash and you will have to send it in. I would though look again at the way your camera is set up for flash fotography.
4/10/2014 5:58:31 AM • Sony Cyber-Shot... • Answered on Apr 10, 2014
REGAIN DELETED PHOTOS
10/26/2011 2:27:44 PM • Sony Cyber-Shot... • Answered on Oct 26, 2011
FLASHES C:13:01
OMG!!! If you still have the camera, try this. I read in one of these forums to spray a burst of brake cleaner in there and blow dry for a few seconds and believe it or not, it worked! That's after me taking it apart to make sure the connectors weren't loose, using the pencil eraser and banging it. I am not making this up. It was my last resort and it worked. Good luck!
9/30/2011 5:37:11 AM • Sony Cyber-Shot... • Answered on Sep 30, 2011
The disc supplied with sony
The drivers needed to connect your Sony camera to a computer and transfer files are already included in the operating system, so you don't have to install anything. If there is a software on that disk to enable you to edit, sort pictures, etc, you could try to Troubleshoot compatibility, by right-clicking on setup.exe located on your cd.
8/1/2011 9:49:24 PM • Sony Cyber-Shot... • Answered on Aug 01, 2011
Sony cybershot camera was accidently
Unfortunately its not made for washing.
It is unlikely it will work again but the folowing has helped on cell phones.
Dry it in a not to warm place (not over 50 degreed centigrade) with good ventilation. Wait for 5 days atleast. If you can take the battery out and the memory card before.
7/5/2011 1:08:42 PM • Sony Cyber-Shot... • Answered on Jul 05, 2011
Where can i find a
You can download and print the instruction manual in PDF format by clicking this link:
http://www.docs.sony.com/release/DSCP30.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
6/23/2011 4:58:41 PM • Sony Cyber-Shot... • Answered on Jun 23, 2011
The lense on my P200 will not retract properly, a
I Hope the steps below should be helpful in fixing your camera issue.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Regards,
Ron
2/24/2011 5:36:14 PM • Sony Cyber-Shot... • Answered on Feb 24, 2011
My sony p2oo cybershot was
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
2/11/2011 12:11:18 AM • Sony Cyber-Shot... • Answered on Feb 11, 2011
My Sony cyber-shot DSC-P100 camera will not shut
You may have a bad on/off tack switch, from your description the camera functions normally, but you can not shut it down. One possible solution is to get a can of electronic contact spray cleaner for pods, Radio Shack carries in stock, or service shop. If you can access the button directly all the better, if this fails you may need a new tack switch.
2/1/2011 9:40:53 PM • Sony Cyber-Shot... • Answered on Feb 01, 2011
Sony Cyber-Shot DSC-P200 Digital Camera Logo
152 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
disc supplied sony
  • Cameras
