20 Most Recent Xact Communication XS034 Boombox Questions & Answers
2answers
Boombox does not maintain connection to radio
Here is the fix,Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife the radio will now play without any problem!
5/11/2014 11:30:04 PM • Xact... • Answered on May 11, 2014
Xact stream jockey 11 sirius boombox xs034
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife your radio will now play without holding it
5/11/2014 11:18:35 PM • Xact... • Answered on May 11, 2014
My xact boombox just stops
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knifeyour radio will now play without holding it
5/11/2014 11:15:16 PM • Xact... • Answered on May 11, 2014
0answers
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
VIBE SOUND USB Turntable Model VS-2001-USBT. Where can I download drivers and application for it please?
Probably nowhere as this is an Amazon / eBay special so made in China. You should be able to go to Windows Settings, - Hardware and tell Winderz to find a compatible driver. https://www.google.com/search?q=VIBE+SOUND+USB+Turntable+Model+VS-2001-USBT+drivers ..
3/31/2024 1:46:10 AM • Audio Players &... • Answered on Mar 31, 2024
I'm looking for a manual to my IQ VOICE ORGANIZER
Hi I have a manual (and an IQ Voice organizer that I'm trying to sell). I would happily send you a pdf file of the manual if you contact me. Robert
3/30/2024 1:52:26 PM • Audio Players &... • Answered on Mar 30, 2024
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour. Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min. How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
3/26/2024 3:32:23 AM • Audio Players &... • Answered on Mar 26, 2024
Vintage Audiosonic CR-06PL Digital Alarm Clock AM/FM. After pressing SET button, wait for blink, then HOUR button does not change hour time???
Questions edited for clarity, full 'make model (what it is)'.Spray the buttons with Electrical Switch Cleaning Fluid Spray. It is an old unit and the contacts are probably dry.https://www.google.com/search?q=CR-06PL..
3/26/2024 2:55:25 AM • Audio Players &... • Answered on Mar 26, 2024
BLACKWEB BWA15HO110 Bluetooth Sound Bar. Everything seems in order with my Blackweb BWAHO110, but I get no sound on my headphone connection.
Blackweb is a Walmart brand made in China at the lowest price point. When they fail, you return them to Walmart for warranty replacement and explain you can't find the receipt. The will give you a store credit. Or you just buy a new one. There are some ideas here https://www.google.com/search?q=Blackweb+BWA15HO1O+but+get+no+sound ..
3/24/2024 1:13:16 AM • Audio Players &... • Answered on Mar 24, 2024
2answers
I can not stop alarm on my caixing cx 868 clock, who can help me
To stop the alarm you have to disable ((all)) the alarms. In (cx-808) you can set 8 alarms; so you have to press "alarm" , then "modify" 8 times. (on the right cornor shows the number of the alarms.)
3/17/2024 3:43:45 AM • Audio Players &... • Answered on Mar 17, 2024
What connections does Harbinger HX 121M stage monitor speaker have please?
Question edited for clarity, 'make model (what it is)'. The images show the rear connections. It looks like 2 x 1/2" jacks and a multi-pin connector for a sound mixer. I have never heard this term before? Passive stage monitor. Uses speakon connection. It is this
Speakon connector
Wikipedia https://en.wikipedia.org > wiki > Speakon_connector Speakon connectors arrange their contacts in two concentric rings, with the inner contacts named +1, +2, etc. and the outer contacts connectors (in the four- ... The company has disowned it! https://harbingerproaudio.com/manuals/
Harbinger HX121M 12" Stage Monitor
Musician's Friend https://www.musiciansfriend.com > pro-audio > harbinge... 12" loudspeaker featuring a 2.5" high-temperature, precision edge-wound polyamide voice coil and an 80 oz. vented magnet structure.
Harbinger HX 121m Passive monitor
Reverb https://reverb.com > Pro Audio > Speakers > Harbinger Passive stage monitor. Uses speakon connection. ..
3/13/2024 11:12:51 PM • Audio Players &... • Answered on Mar 13, 2024
My mp3 is in Chinese. How do I get it in English ? Model : WH-MP4 2GB-W
This might sound silly but it's how I did it. I went to a small, local Chinese takeaway at a quiet time during the week. When ordering food I very politely asked the person serving if they could help. They sorted mine out in a couple of minutes while I was waiting for my food.
3/10/2024 7:06:52 PM • Audio Players &... • Answered on Mar 10, 2024
Can i get a connector for the ribbon cable for JVC UX-A4 stereo?
If you sacrifice the Cassette player functionality, you should be able to use pin 6 as ground and cut pin 7 and 8 in the ribbon cable to use as an AUX input instead of the cassette player. At least that's what I'll try.
3/7/2024 10:48:48 AM • Audio Players &... • Answered on Mar 07, 2024
2answers
Where can i find the band for a optimus sct 5500
I have the mesures (in cm) of each one. See the picture. You'll need 2 pairs (1 pair for each engine). correias tdoptimus-uuzacmb33pxxi3kifnudeqkt-d-1.jpeg *esticada = stretched; espessura = thickness
3/1/2024 6:51:05 PM • Audio Players &... • Answered on Mar 01, 2024
Xact Communication XS034 Boombox Logo
3 questions posted
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Xact Communication Audio Players & Recorders
Most Popular Question
  • Audio Players & Recorders
