20 Most Recent
Nortel Norstar M7310 Display Phone Questions & Answers
How to Change COS (Class of Service) Password
If you set the all line and set restrictions to no restrictions, you are not restricted from making any calls. I don't think it's the phone system requiring this 4 digit code. Are you sure all your lines are set with the same long distance provider. Did the lines in the dial 8 group require a code. (ie some users had the long distance provider set up their lines to need a code entered to charge calls off to different job codes, so they can distribute the charges correctly).
You should now be able to call 9+1+area code+number, with no restrictions.
Nec telephone manuals
Answer> Manuals: If you want FREE manuals for your device, you must go directly to the maker of your hardware device. Look for their SUPPORT (Drivers and Downloads) and input the required data such as the Make, Mod. of the device in question. They will then take you to the proper section where Drivers and Manuals are located. Here you simply select the option you want to download and install your drivers or open a manual. Manuals often come down in PDF format and require Adobe Reader. Get Reader form http://www.Adobe.com .
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
14 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
