20 Most Recent Nortel Meridian M2616 Phone with LCD Display - BLACK Questions & Answers
Answer> Manuals: If you want FREE manuals for your device, you must go directly to the maker of your hardware device. Look for their SUPPORT (Drivers and Downloads) and input the required data such as the Make, Mod. of the device in question. They will then take you to the proper section where Drivers and Manuals are located. Here you simply select the option you want to download and install your drivers or open a manual. Manuals often come down in PDF format and require Adobe Reader. Get Reader form http://www.Adobe.com .
Nortel Radio... | Answered on Dec 24, 2013
Connect the headset to the charger as if you were charging it, but keep one side in your ear. Once connected to the charger, hold down the power button. It'll beep a few times and then stop. Disconnect from the charger. You can then turn the headset back on. This "procedure" clears the headset's memory,
Radio... | Answered 3 days ago
Radio Shack has a pretty good search feature for old instructions on their website. You will need their part number off the unit, which will be something like "20-321". Do a search and you can get a PDF instruction manual for it online.
Radio... | Answered on Oct 14, 2019
Tip
How to manage a long waiting queue in restaurant/clinic/service centre?
In Singapore, we noticed that many restaurant/clinic/service centre/etc usually forms a long queue either waiting for table or seeing a doctor or waiting to be served.
It seems that none of the owner are keen to look into a better system to resolve such unpleasant situation. In fact, you will notice that loss of business due to frustration queuing (esp. restaurant), angry customer (esp. service centre) and fear of contact (esp. clinic) in most cases.
Here is a great solution that I would like to introduce to have the above issue resolved. Check out the paging system by Blufi Wireless Singapore Pte Ltd, it helps to resolve most queuing challenge.
on Oct 09, 2019 | Radio Communications
go to cellphones. This is radio communications
Radio... | Answered on Oct 04, 2019
Your antenna should not make any difference with power or receiving. Is the scanner mobile or in a room? Hard to imagine the connector being broken. You could test the antenna or even the BNC connector on the scanner. Try another antenna. If you wiggle it, does it start receiving? You may have a short in the BNC to the receiver. Other than that, look to power issues.
Radio frequencies are different from country to country. NZ will use different frequencies than Canada. Canada and the USA have agreements in place because they border each other on what freq. is used for what. NZ likely has its own list. Your radio is not programmable to NZ frequencies. Sorry!
It sound like your power supply is not providing enough output for the radio. Are you by chance using a wall wart for power? You need a dedicated 12 volt power supply, made by Astron, QJE, or Pyramid.
Radio... | Answered on Oct 03, 2019
you may have a bad squelch pot on the radio. try turning it fully in one direction an back in the other direction. it also could be that the Pot is dirty get some contact cleaner and open up the radio and squirt a very little cleaner into the open spot of the Pot. then rotate the know several times. if you do not have something like CRC QD Contact Cleaner you can get it in a good hardwood store like ACE or TrueValue, and even Home Depot. you can use only 91-99% Electronic Grade Isopropyl Alcohol, do not use the 70% Isopropyl Alcohol.
you may have a broken wire in the radio itself? or there is a wire broken inside the mike itself not just the connector.
Nortel Meridian M2616 Phone with LCD Display - BLACK Logo
2 questions posted
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
MrFixitSTTL
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Radio Communications
Most Popular Question
change message
  • Radio Communications
